LS1 Brake Upgrade
Old Apr 21, 2018 | 04:40 PM
Randy_M's Avatar
Car: '92 RS Camaro
Engine: '92 SD 305 TPI
Transmission: BW 5 speed
Axle/Gears: Stock Open 3.08:1
LS1 Brake Upgrade
I currently have the LS1 upgrade on a '92 RS Camaro and I am exploring moving up to either the C5 or C6 13" rotor size to better fill up my 17" wheels. Can someone update me on whether I could just install the C5/C6 caliper bracket and larger rotors or would it be necessary to change hubs and/or further modify my spindles? I also believe my current caliper will work. It appears that plan might be workable but I want to ensure it will before I proceed further. Any help with this is appreciated.
Old Apr 21, 2018 | 08:19 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: LS1 Brake Upgrade
Big brake Upgrade.com will answer all you questions and have any parts you need to do the swap.
Old Apr 21, 2018 | 09:43 PM
skinny z's Avatar
I don't know the answer but I'm guessing you can find it here as well.
http://lukeskaff.com/projects/car/th...brake-upgrade/
smohmand
Brakes
Aug 31, 2013 11:35 PM
DF'sCamaro
Brakes
May 26, 2008 11:59 AM
ebmiller88
Brakes
Aug 31, 2004 03:41 PM
