Rear brakes with ATS fronts?
Old May 31, 2018 | 05:04 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
MY front brake upgrade plans include ATS calipers and the bigger rotors, but what do you suggest for the back that looks compatible, visually?
Old Jun 7, 2018 | 05:23 AM
BBU.COM's Avatar
Top Answer: 1
Re: Rear brakes with ATS fronts?
The 2010-15 camaro V6 rears are a good match, 12.4 rotor w/ single piston floating caliper, you need a 17 with some spoke room for those however
Old Jun 15, 2018 | 04:18 AM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
I found a very cool caliper on rock auto, p/n ac delco 1722503 that is under $200. It looks like a nice match for the ATS ones for the front... thoughts?
Old Jun 15, 2018 | 05:50 AM
BBU.COM's Avatar
Top Answer: 1
Only thing is is that caliper uses a 14.4 inch rotor. The Gen 6 camaro ss rear caliper is less $ and uses a 13.3 rotor, so it actually would be a closer match
Old Jun 15, 2018 | 08:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You also don't really want a fixed rear caliper, since the axles have c clips there is some play in and out and this can cause pad knock back issues.
Old Jun 21, 2018 | 01:59 AM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
Do you have a part number for the Gen 6 ss rear caliper?
Old Jun 21, 2018 | 05:13 AM
BBU.COM's Avatar
Top Answer: 1
AcDelco 172 2716 & 172 2715 We use the C7 J55 (z51) rear rotors with these.
brodysZ28
Brakes
Apr 30, 2017 06:46 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
T/Atime
Wheels and Tires
29
Nov 13, 2011 11:23 PM
kairles
Dec 19, 2006 11:14 PM
