91 camaro front brakes
Old Jan 5, 2019 | 10:34 AM
64camo91's Avatar
my front brakes on my camaro are making a rattling noise and a screaming noise when i am just driving along this stops when i just touch them.the brake pads are brand new and i bled them . anyone know what the problem is.
Old Jan 5, 2019 | 01:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 91 camaro front brakes
Did you clamp down on, bend into place, the locking tabs on the outer pad? IIRC, the inner pad uses a spring like retaining clip, is it in place?
Also, be sure to bed the pads.
RBob.
Old Jan 6, 2019 | 07:48 AM
64camo91's Avatar
its the outer pad causing all the trouble.do you clamp the two tabs on the outer pad so it fits tight on the caliper . the passenger side is fine no noise or rattling at all/
Old Jan 7, 2019 | 12:41 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
FWIW...
Pad Clinching - See attached.
In all the years of doing GM disc brakes (at least far back as 1968), I've never bothered to do this until I decided to read the 1987 Camaro FSM in 1989.
Old Jan 7, 2019 | 06:49 PM
Beeman's Avatar
You can do the channellock plier deal, but's usually not easy. You can remove the pad and tap the tabs and then reinstall the pad. Or you can have someone hold the brakes while you pry up on the pad and tap on the tabs with a hammer. different way to do the same thing. Be sure the inner pad has an anti rattle clip and that it is tight in the piston. Replace the o-rings in the caliper and lube with silicon based lube and clean or replace the sliders that the bolts go through. Also clean and lube the caliper stops, the part of the spindle that hold the caliper.
iroc stangs
Brakes
Mar 30, 2019 09:15 AM
88fastgta
Brakes
Jun 26, 2011 10:34 PM
calioak510
Dec 28, 2009 01:50 AM
92Z
Mar 9, 2004 01:02 PM
Night Hawk
Sep 21, 2000 08:48 PM
