12" 1LE brakes for the rear?
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I currently have the 11.65" 1LE brakes on the rear of the car now and I'd like to go to a 12" rotor but keep the caliper and bracket I have now. Does someone make a disc brake backing plate/mount for a 9 bolt that will accomplish this? I know it's not going to dramatically increase performance, it's mainly for cosmetics to help fill out behind the wheel.
Engine: 4++,350 & 305 CIs
Re: 12" 1LE brakes for the rear?
Not that I've seen but haven't really looked hard. I have seen some racecars with front 2piston pbr 1LE calipers on the rear but not sure which rotor was used (think it was a stock c4 non hd front rotor and caliper combo)
Which 12" rotor would you use for that?
Car: 90 Formula
I figured I'd use the 12" x .81" C4 rotor. I've got an email sent to bigbrakeupgrade and was considering reaching out to Ed Miller to see if he could help.
