85 iroc 4w disk. All new - brakes still suck - cant lock up
85 IROC 4w disc - all OEM stuff
Car has new calipers, new rotors, new carbon, metallic pads, new rubber lines, a new master, the prop valve was rebuilt and I still feel like the pedal is spongy -
i get a slow stream out of the rear calipers when bleeding but it doesnt shoot out!
more pressure in the front for sure when bleeding but Im still not happy.
for reference, i have 6 other old cars - from the 60s and they all have a firm pedal and you can easily lock em up if you tried where as with this one, You absolutely cannot lock this car up on dry pavement
I did the Granger spring swap in the prop valve as well
what else could it be?
Or are these cars just that bad braking wise?
Engine: 5.7 L98
Re: 85 iroc 4w disk. All new - brakes still suck - cant lock up
I have an 88’ GTA with Delco moraine 4 wheel discs as well and what I did to improve braking performance was add a Wilwood adjustable proportioning valve and braided stainless brake hoses by Goodridge (improved pedal feel).
I noticed the most improvement with those mods, I also run Stillen pads in the front. I pretty much followed a thread about ultimate stock brake set up by a few other members.
I tried the prop valve spring mod too and not long after developed a leak from there…
The brake hoses I replaced looked rough, especially the rears which were date coded originals and I replaced the hard lines on the axle as they were looking rusty.
Engine: 4++,350 & 305 CIs
Those rear iron calipers.... suck to put it mildly.
Aaronl84
Brakes
19
Jul 14, 2023 08:49 AM
