brake lines for quick performance?
Old Sep 17, 2023 | 03:54 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
I'm installing a quick performance 9inch rear end. will factory disk brake lines work with their brakes of do i have to use their kit?
Old Sep 17, 2023 | 06:41 PM
Re: brake lines for quick performance?
Most likely the factory lines won't "fit", at least not directly; not least because the Frod 9" center section isn't centered the same way a GM rear would be. Which means one factory line will be too long (manageable) and one will be too short (my line stretcher is broken right now).
So yeah, you'll probably need to do SOMETHING. You probably don't "have to use their kit", but you'll have to do SOMETHING besides stock. Might even have to buy a stick of brake line at the parts store down at the corner and bend it up to fit.
Flex hoses would depend dramatically on the calipers you use.
Old Sep 19, 2023 | 08:20 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Most likely not. Just buy their kit if you're already spending a bunch of money on new stuff. That said I used a set of 4th gen brake lines on my Midwest chassis 9". I just needed to bend the lines a little differently
Old Sep 19, 2023 | 09:13 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I just made new lines for my 9in. It was easy and less expensive than buying pre bent lines and modding them. It came out looking as good if not better than stock.
Old Sep 20, 2023 | 05:51 AM
Evilokc's Avatar
Engine: tbi 305
i got a hold of quick performance. looks like i need lines for a 98 ford explorer.
Old Sep 22, 2023 | 04:01 PM
malibudave's Avatar
DO NOT buy the flex line kit
Use hard line down the length of the axle.
The long length of flex line will give you a spongy pedal. Always try to keep your flex lines to a minimum.
Old Jun 29, 2024 | 09:05 AM
brando278705's Avatar
Car: 1987 Camaro IROC-Z
Engine: 5.7
Axle/Gears: 3.70
did you ever pick up the 98 explorer lines? Curious how it worked.
Chuck84TA
Brakes
Jan 24, 2013 11:25 PM
brianfromhawaii
Jun 30, 2009 07:53 PM
StealthElephant
Brakes
20
Jan 12, 2004 01:48 PM
Pepsicola
May 4, 2003 04:26 PM
MikeDwhoROCZImports
May 9, 2001 12:17 PM
