Issue with one wheel locking up when hard braking
Old Oct 7, 2024 | 08:16 AM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
Not sure if this is normal or not since those cars have no ABS but I figured I will ask. I have a 92 RS with V6, front disks and rear drums. The car is pretty much all original. All brake hardware (rotors, pads, calipers, drums, drum hardware, shoes, etc) was replaced. I have a new rear brake line (from the master cylinder and also the one over the rear axle going to the rear brakes). The front brake line is original as is the brake booster and prop. valve (or at least whenever they were replaced last time as I just own the car for less than a year). The car brakes fine but when I slam the brakes harder, the rear passenger wheel will lock up and the car slides on the road a bit. Is that normal operation or should I diagnose and replace more parts in the braking system?
Old Oct 7, 2024 | 12:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Issue with one wheel locking up when hard braking
Rear drum may need to be adjusted and backed off a little.
Old Oct 7, 2024 | 01:00 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Yeah, sounds like an adjustment is needed. Usually these will self adjust if you back up and pump the brakes but maybe something is gummed up in the mechanism. Pop it apart and look.
LarryD
Brakes
Sep 7, 2023 10:17 PM
tunatrky
Brakes
Oct 28, 2014 07:04 AM
Dark Ember
Brakes
24
Sep 3, 2013 09:19 AM
xot86iroc
Brakes
16
Dec 28, 2011 10:43 PM
