E brake 2000 gen 4 rear end into gen 3 89 Firebird
Old May 28, 2025 | 02:09 PM
Elwoodwrigley's Avatar
Hi all, can anyone tell me if I can use the original e brake cables with an adapter or straight on or do I need new cables? Has anyone done this to there gen 3 - I put in a gen 4 for disc break and posi out of a 2000 Camaro. Thx in advance
Old May 28, 2025 | 02:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: E brake 2000 gen 4 rear end into gen 3 89 Firebird
Yes its been done and there are a million recipes out there from folks using all kinds of cables. Hawks also sells a kit but I did not have luck with it. Spend some time using the search function as you'll see there is a lot to read.
Old Jun 2, 2025 | 11:39 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
I'm using the Hawks swap cables in my 91 Z with 2000 Camaro rears and while they do fit great and go in all the right places without issue they do not have that little spring on the caliper side of the cable to take the extra bit of slack out. I've heard of guys using these springs I got them on Amazon for like $10. So one of these days I'll put them on. It's not really high on my priority list
Old Jun 3, 2025 | 07:39 AM
Thanks' .. I will check it out. So the extra slack in the line is not a big concern.
56–57 inches for the gen 4 and the 43.4 inches of the original gen 3 Fire-bird cables) -- Do I have to cut these or is that spring you showed how I sure it up? Where does the spring go if so?
Than you in advance
Old Jun 3, 2025 | 09:11 AM
thatsupnow's Avatar
Than you in advance
The spring goes on the loop end of the cable that attaches to the caliper itself
Coldstart
Brakes
May 13, 2026 08:47 AM
425HP Z28
Nov 10, 2013 08:00 AM
BigWhiteGTP
Brakes
Apr 7, 2006 12:12 AM
Mikes89bird
Sep 9, 2003 07:04 PM
87transam5.7tpi
Mar 10, 2003 11:37 AM
