1986 Supercharged IROC
Car: 2001 VW Passat
Engine: 1.8 Turbo
Transmission: Automatic 5 speed with Tiptronic
Axle/Gears: Stock
I am selling my 1986 IROC Camaro. It is a T-Top body. The car has been extensively worked over. I have the following in the vehicle:
Engine:
Supercharged 360 Small Block Chevy
o K&N Xstream Air Flow Air Filter Assembly
o Holley In-line Blue Electric Fuel Pump with Regulator and Gauge
o Edelbrock 750 CFM Performer Carburetor tuned w/ Jets, Rods, Springs and Stubstack (1/2'' fuel system with high flow fittings, not yet installed)
o B&M 144 Roots Supercharger with 10 psi pulleys
o Ported and polished heads with valve job
o Bronze valve guide inserts
o ARP Head bolts
o Comp Cams Hydraulic NX268H-13 Blower camshaft and lifters
o Comp Cams Raised Guide Plates and ARP Rocker Arm Studs
o Manley Street Master Swirl Polished Intake/Exhaust Valves
o Comp Cams dual spring oversized Valve Springs
o Comp Cams 10 degree racing locks and retainers
o Comp Cams Valve Seals
o Comp Cams Heat Treated Pushrods
o Summit Racing 1.5:1 Full Roller Rocker Arms and Lock Nuts
o Billet Double-Row Roller Timing Chain with Thrust Bearing
o Edelbrock Tubular Exhaust System and 3 inch exhaust into Flowmaster 70 Series Muffler and Welded in Cut-Out w/ Electric Valve
o MSD 6AL Ignition Box
o SBC Distributor with Hypertech 53k Volt Coil, Cap and Rotor
o MSD Extreme HEI Distributor Cap and Rotor
o MSD Distributor Advance Kit
o Crane Cams Adjustable Vacuum Advance Canister
o MSD 8.5mm Spark Plug Wires
o Autolite 2 stage cooler Spark Plugs
o Chevy 350 block bored, champherd, torque plated, align bored and surfaced
o ARP four bolt main bolts
o Chevy 350 Crankshaft Cleaned and Polished
o Chevy 350 Rods polished and ARP Wave-loc bolts
o JE Dished -24cc Forged Blower Pistons
o JE Hellfire Rings, Straight wall pins and Spiro locks
o Clevite 77 Cam, Rod and Main Bearings
o Summit High Volume oil pump with welded on pickup
o Stud kit and ARP Oil Pump Driveshaft
o Moroso 6-qt, baffled oil pan for Third Gen Camaro with one piece Fel-Pro Gasket
o Edelbrock Victor Series Water Pump
o 180 degree Thermostat
o Copper 3-core radiator and Electric cooling fan setup with relays
o Fel-Pro Gaskets throughout the whole motor
o SFI Certified Flexplate and 8 inch Steel Damper
o Whole rotating assembly balanced in and out of the motor
o Chrome Dress Up Kit
o Tuff Stuff Gear Reduction Mini Starter
o Optima Red Top Starting Battery
o B&M SuperCooler Engine Oil Cooler with Electric Fan
Suspension:
BMR Adjustable Panhard Rod
BMR Bolt-in Lower Control Arm Relocation Kit
34mm/24mm Factory Sway Bars
Eibach Pro-Kit Lowering Springs
Spohn Tubular Rear Lower Control Arms
UMI Tubular Adjustable Torque Arm
Energy Suspension Polyurethane Sway Bar Bushing Kit
Z-28 Tight Ratio Steering Box and New Power Steering Pump and Hoses
Chassis:
Weld-in Subframe Connectors
Edelbrock 3-Point Strut Tower Brace
Factory Steering Brace Wonderbar
Factory Triangular Front Frame Mounts
Transmission:
Pro-Built TH700R-4 Transmission
Polyurethane Transmission Mount
TCI 11 Breakaway Torque Converter
Summit Steel Transmission Pan
B&M Super Cooler Kit
Rear End:
3.27:1 Borg-Warner 9-Bolt Rear End (new carrier and cones)
TA Performance Rear End Girdle
Reider Racing Master Overhaul Kit
Shimmed Positraction Unit for Zero Clearance
Wheels/Tires:
16 x 8 Polished Aluminum IROC Wheels
Falken 245/45ZR16 Tires
Brakes:
1LE Rear Brake Kit
New Brake Booster and Proportioning Valve
Modified Proportioning Valve for 50/50 Brake Pressure
Body:
3 Cowl Induction Hood with Oil PSI Gauge Mounted inside Cowl
Two Sets of T-Tops one for daily use and the other in T-Top bag for shows (like new set)
Clear Side Turn Signals, Clear Front Turn Signals and Fog Lights mounted w/ Factory Fog Light Switch
H4 Conversion Headlights
Custom One of a kind LED Taillights in Factory Housing
Front and Rear Taillight Blackouts
Interior:
4th Generation Black Leather Front Seats (Power Driver Seat)
IROC Black Leather Door Panels
Grant Racing Steering Wheel
B&M Megashifter
145 MPH Speedometer and White Face Reverse Glow Gauges
Autometer A-Pillar Dual Gauge Pod with Oil and Transmission Temp Gauges
Autometer Vac/Boost Gauge and Air/Fuel Ratio Gauge
Brand new Electric Rear Hatch Pull Down Unit
Electric Mirrors
New Switches for everything (mirrors, locks, windows, hatch, ignition switch, headlight and fog light switch, and reverse light switch)
Crimestopper Alarm System with Two Key Fobs
Brand New Black Dash Board
I am asking $12,500. If you are interested please send me an email and I will glady send you pictures. I am in Topeka, KS but the car runs so it can be taken anywhere. Please serious buyers only. I am selling because I have started a new project and need the room in my garage for it. Thanks for looking!
Cory
Engine:
o ARP Head bolts
Suspension:
Chassis:
Transmission:
Rear End:
Wheels/Tires:
Brakes:
1LE Rear Brake Kit
Body:
Interior:
B&M Megashifter
Electric Mirrors
Cory
toronto formula
Nov 10, 2015 06:17 AM
mustangman65_79
Aug 11, 2015 03:17 PM
