looking for 350 camaro in SE pa
Car: 82 Z
Engine: 350 carb'd
Transmission: th-350
Axle/Gears: 3.08 posi
hello
i am looking for a camaro, it can be any year, but i am looking for mileage on the lower side, something around 100k or lower, and i need a 350, l98 or crate, as long at it is a 350. i also need it to have the smog equipment on, becuase i need to be passing the pa emission test once before i can get it exempt. no rust, and if it has t-tops, they cannot leak. also, be in reasonable distance from lower bucks county, no more than an hour or so drive.
thanks
thanks
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i might have something for you, im in maryland though, and im not sure how far it is. crate motor, rebuilt tranny with warranty, new rear, full tune up, new interior, etc. check out the ad.
https://www.thirdgen.org/forums/cama...ml#post2921795
thanks.
thanks.
camaro 350
HI I have a 1970 camaro z28 clone yellow with black strips for 10,500 if you interested get back to me at crissylynn85@aol.com Thank you
Car: 91 TA VERT 5SPD 2 5.7 89 GTA VERTS
Engine: 5.7
Transmission: MANUAL/AUTO
I have a 88 Camaro Convertible 350 TBI Police Intereceptor motor/trans. New paint, new interior, new everything. I am in Reading, Pa. Let me know if you are interested.
Car: 1991 Camaro RS T-Tops
Engine: 350 TBI now carbed
Transmission: replaced T5 w/new clutch
Axle/Gears: New 3.73 posi
its a 91 camaro rs used to be 305 TBI now 350 TBI..i took out the AC compressor and re rerouted the serpintine belt to just run the water pump, crank, alternator, and power steering, the smog pump is still attached, but not hooked up. none of the emissions are hooked up but i have everything to put back on it if you want it. i have new chrome valve covers, new spark plug wires (many sets) if you want them, bosch +4 spark plugs installed, new edelbrock shorty headers with replaced collectors and a cutoff flange installed with a remote switch. The exhaust is Flowmaster and there is no rust whatsoever on the car. I have installed a multi-color LED underbody kit and an oogah horn in addition to the regular horn. New struts (lift supports) on the hood and hatch, T-tops are in great condition with no scratches and has leaked once on me through a car wash...needless to say i hand wash it now. i just put in a remanufactured T-5 transmission because i didnt like mine and a new Luk clutch. I replaced the rear gears from 3.23 to 3.73 because of wear. Has IROC rims with newer Nankang tires with excellent tread. Never been in an accident, has a few paint scratches that i have touch up paint for but never got around to it, no dents, minor ding on the hood (not noticible from far away), original white paint, original red interior with minor tears in dirver seat from normal wear. New Sony X-plod head unit with new Bazooka 4 Channel amp that powers the front Boston Acoustik and the rear JBL 6x9. Also new Boss amp that powers the 2 PPI 10" subs with remote amp control. I just installed a air/fuel ratio gauge for when the car was carbbed. New Sylvania Halogen Lo-beam headlights (the high intensity ones) and a replaced ignition switch in the steering column. I still have a few more mods i want to do but let me know what you think, i am going to college in Texas but the car is still in jersey with the title and i need to get rid of it so i can get something down here. Thanks for looking and let me know what is going on. Im asking 4000 but make me an offer i need this car to go..thanks
email to deangraboyes@gmail.com for pics and questions
i can put back on all emission equipment to pass PA emission
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L TPI L98
Axle/Gears: 3.23 posi/limited slip
Re: looking for 350 camaro in SE pa
i bought this car from a guy in pa and trying to sell clean emissions
You are viewing my all original 91' Z-28.
51,000 miles
$13,000.00
"The Vitals":
Engine:
5.7L TPI (Dynoed at 213hp. (to the wheels) 315lbs. tourque)
Transmission
700R4 Automatic transmission with overdrive
Exhaust:
TPI Manifolds with dual catalyst 3" catback exhaust with dual 2.5" outlets
Drivetrain:
3.23 gear ratio with positraction/limitedslip
Wheels and Tires:
16 inch aluminum alloy powder coated wheels (factory)
Goodyear Eagle HP's 245/50R/16
Exterior:
Arctic white, Blister Hood, Fog Lamps, Ground Effects, Ferrari Style Spoiler
Interior:
Red Leather
Power seats
ps,pdl,pw,ac,heat,rear defrost, steering tilt, cruise control, tachometer, pm, pb, electric rear hatch, courtesy lights, dome lights, vats, red carpet, black trim, body by Fisher
This is vehicle is STOCK.. no aftermarkets mods... original paint, tires, wheels everything is original.
I Have All Original Documentation On This Vehicle (window sticker, owners manual, build sheet, life insurance papers, tire warranty info, 91 Camaro Brochure, and Information Tape).
If Interested Please Call:
770-652-5942 Or 678-633-2391
Email: kevin_d_king@yahoo.com
Serious Inquiries Only Please.
You Can View Pictures At
http://www.cardomain.com/ride/22988
51,000 miles
$13,000.00
"The Vitals":
Engine:
Transmission
Exhaust:
Drivetrain:
Wheels and Tires:
Exterior:
Interior:
Red Leather
Power seats
