[NY] WANTED:RUST FREE 82-92 Z28 OR IROC-Z ROLLER SET UP FOR MANUAL TRANSMISSION
Car: 1991 camaro z28
Engine: 305 tpi
Axle/Gears: G80 G92 3.42
I'm in the western New York area and I'm looking for an 82-92 Z28 or IROC rolling chassis that is set up for manual transmission. Would prefer if it was as complete as possible with exceptions of course. Rust free is really a must.Will travel for the right car. A clean title will be necessary too. Let me know prices pictures and any info you have. Thank you!!
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Re: WANTED:RUST FREE 82-92 Z28 OR IROC-Z ROLLER SET UP FOR MANUAL TRANSMISSION
I have a 1988 IROC roller that I'm looking to pass on to someone more likely to finish it than me. It's a T-Top car with a clean MA title. The body is completely rust free and I was in the process of bringing it to bare metal. The underside of the car is clean and painted, all suspension parts are new or refurbished. All the parts are there, it just needs to be reassembled. I have a 350 TPI motor (heads were just done), a T5 trans, and a 9-bolt posi BW rear with 3.27 gears and disk brakes. Many other parts go with it including an aluminum driveshaft, Hurst shifter, New front rotors and calipers, new shocks and struts, etc. It was an automatic originally, but I put the pedals in it for the T5. Boxes of parts that are all bagged and labeled. It also has a 6pt cage in it (I have the 2 bars to make it an 8pt). Also has welded in Hotchkis subframe connectors so the body should be extremely rigid. All the hard work has been done, what's left is a great project for someone looking to build a car. Here is a sampling of what's been done.
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
what you lookin to spend got a complete car with t56 i'm pulling motor and trans has extras located in south jersey
Engine: 305 tpi
Bought a 4th gen car thanks anyway
