JBL Amp and Dual 10" Subs
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Details:
JBL 1-Channel Car Amplifier - The JBL GTO301.1II 300 watt Mono Subwoofer Amplifier produces high-output MOSFET power supply to ensure optimum power delivery for numerous impedances with low distortion, which creates amazing sound quality. This amplifier also features a 12 dB per octave electronic crossover, allowing for optimized bass performance.
Product Details
Web Code: 10063637
Mfr. Part Number: GTO301.1II
# Of Channels 1
1 OHM Output Power - Full Range Info Not Available
14.4V Dynamic Power At 2 Ohms 320 Watts
2 OHM Output Power - Full Range 320 Watts
4 OHM Output Power - Full Range 204 Watts
Bass Boost Yes
Bridgeable Yes
Bridged Power At 2 OHMS - Full Range 294 Watts
Bridged Power At 4 OHMS - Full Range 204 Watts
External Bass Control Capable Yes
Fuse Rating (Amps) 30 Amps
High Pass Filter No
Included In Box Amp, Instruction Manual
Input Voltage 4.7 Volts
Low Pass Filter No
Mosfet Switching Yes
Overload Protection Yes
Product Dimensions 31.27(W) x 6.03(H) x 29.54(D) cm
Product Weight 5.55 kg
Protection Indicator Yes
RCA Inputs (#Pairs) 2
RCA Outputs (#Pairs) 2
Screw Type Terminals No
Signal to Noise Ratio 77 dBA
Smart Engage Turn-On Yes
Speaker LVL Inputs No
Total Max Power 320 Watts
Tri-Mode Capable No
JBL GT4-10 10" 1000W sub - Polypropylene woofer cone delivers exceptional attack resulting in incredibly tight bass response.
Butyl rubber surrounds offer ideal cone-edge suspension and also guarantee long-term reliability by rejecting moisture and ultraviolet contamination.
12mm Linear one-way X-max and dual 40oz(80oz)magnets make this subwoofer a great choice for high output applications.
Progressive spider provides better control at excursion limits than more commonly used linear spiders.
SPECIFICATIONS
General
Frequency Response 28Hz - 500Hz
Sensitivity 90dB
Impedance 4 Ohms
Voice-Coil Diameter 50mm
Cut-Out Diameter 232mm
Mounting Depth 150mm
Overall Diameter 258mm
Vas 40.14 liter
Qts 0.42
Fs 29.6Hz
Qes 0.45
Qms 6.45
Matched up with a no ported sub box(measurement in inch's) 22.5wX12hX12d
items are used, but in very good shape. Subs were never pounded, and amp was never worked hard.
looking to get;
JBL amp - $150
JBL subs/box - $200
Combo - $300
matt.tremblayZ28@gmail.com
Product Details
Web Code: 10063637
# Of Channels 1
Bass Boost Yes
Bridgeable Yes
High Pass Filter No
Low Pass Filter No
Tri-Mode Capable No
SPECIFICATIONS
General
Sensitivity 90dB
Impedance 4 Ohms
Vas 40.14 liter
Qts 0.42
Fs 29.6Hz
Qes 0.45
Qms 6.45
looking to get;
JBL amp - $150
JBL subs/box - $200
Combo - $300
