Canadian Region Take off to the Great White North.
Uncontrolable Headlights
Old Jan 25, 2009 | 11:31 AM
Je90GTA's Avatar
Car: 90 T/A GTA
Engine: LB9 305
Transmission: 5 speed
I have a 90 TA GTA,with headlight problems.As soon as I turn the key ahead the lights pop up and turn on, even with the light switch in the off postion. Sometimes while driving the car, they will go down. When this happens I can operate them with the switch as normal. I haven't attemted to replace or repair anything yet, I wanted to get advice on the problem rather than waste time and money.
Old Jan 25, 2009 | 11:39 AM
Stephen's Avatar
Car: 87 GTA
Re: Uncontrolable Headlights
Sounds like the headlight switch itself, has a short circuit in it.
I'd bet a new switch would cure the problem.
Old Jan 25, 2009 | 05:52 PM
Je90GTA's Avatar
Car: 90 T/A GTA
Engine: LB9 305
Thanks I'll give it a try.
Old Feb 1, 2009 | 09:19 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
1990 gm canadian cars should have a light sensonr possible by rh front speaker in dash pad. i know camaro does because my 92 will turn its lights on by itslef were as all my other cars are us and don't have that feature. so i would say your car is normal
luke
Old Feb 6, 2009 | 07:57 PM
koolbreeze92's Avatar
Car: 1992 Brilliant Red Metallic with T-
Engine: LB9 305 TPI
Transmission: MD8 4 Speed Automatic
Axle/Gears: 2.73....Paint peeler
I have a 92 T/A and it does the same thing. Because we live in canada we have to have day-time running lites on 24 hrs a day. They probably pop up in the shade and go down in the sun. A cloud will even make them pop up again......Pain in the a#s if u ask me.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
