JL sub ?
Old May 10, 2002 | 06:51 PM
caleb's Avatar
Car: 89' Iroc
JL sub ?
ok here goes, i was going to get 2 cerwin vega vega series 12's but found out it wouldnt work, so now i am thinking 3 JL 12W0's would it be best to get 3 4 ohm ones, or 2 4 ohm ones, and one 8 ohm one, then wire the two 4OHM ones in series, ans wire that with the 8OHM in parallel to the amp, giving me a total of 4OHM, (I think, if anybody can confirm this, that would be great!)
or should i just get three 4OHM and wire em all parallel?
which would be the most efficient?
Old May 11, 2002 | 12:45 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
It all depends on the load your amp is willing to handle. What amp do you plan on using? Might I suggest you get something higher then W0, like maybe a W1 or W4.
Old May 11, 2002 | 08:05 AM
caleb's Avatar
Car: 89' Iroc
i plan on using either a jl500/1 or the kicker ZR360, the reason i am going with W0's i can get three of them for the price of one W3, i can get all three for $200
Old May 11, 2002 | 08:22 AM
pimpinthaz28's Avatar
you should be able to get 4 w0's in a box for about $200. Are they used? if so I would say save your money for the w3's.
Old May 11, 2002 | 08:29 AM
caleb's Avatar
Car: 89' Iroc
no, there all new, but where could i get 4 for $200 ?
Old May 11, 2002 | 07:46 PM
nagga's Avatar
you should never use different ohm speakers on the same amp, get all 3 in a 12ohm model, then the amp will see 4ohms, or get 3 8ohm subs and the amp will see 2.7ohms
and dont buy W1 subs, they are not better than W0s, they are just shallow mounting subs, they even cost the same
