Is this possible?
Old May 17, 2002 | 10:06 AM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Is this possible?
can i run four speakers off a 2-channel amp??
i'm thinking no, but then again i dont know everything...
Old May 17, 2002 | 10:07 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You can hook up as many speakers as you want to as long as your amp can handle the ohm load.
Old May 17, 2002 | 10:35 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if you're thinkin of doing the front and rear off a 2-ch amp, you'll be able to do it if the load isnt too much, but you will lose the ability to fade from front to rear.
Old May 17, 2002 | 09:37 PM
Car: 1986 Camaro SC
i have four 4ohm speakers, the amp puts out enough for 150 a piece in 2ohm stereo, is this what i would end up with if i put 2 four ohm speakers in each channel??
Old May 17, 2002 | 11:02 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Yes, if you connect two 4 ohm speakers in parallel + to + and - to- then each channel of your amp would see a 2 ohm impedance and would produce 150 watts per channel as per your amps specs.
Old May 19, 2002 | 02:57 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
anything is possible
