Came across this........any help?
Old Jun 14, 2002 | 11:56 PM
RICHRAD's Avatar
While restoring my factory radio dept with a oem harness, I disconnected a medium size orange wire. About 18" long ,it has a in line fuse and what appears to be a black plastic box inline also. What is it?
Old Jun 15, 2002 | 08:39 AM
coalyard's Avatar
Sounds like a constant +12 volt wire with an inline fuse. While most after market radio harnesses have the yellow wire as constant +12v, some others are different. I take it you are replacing an aftermarket deck with a stock one, right?
Old Jun 15, 2002 | 04:22 PM
deadtrend1's Avatar
I thought that big square box was a noise filter ......
Old Jun 15, 2002 | 09:24 PM
RICHRAD's Avatar
oops!!! should I have left that on there??:lala:
Old Jun 16, 2002 | 12:40 AM
coalyard's Avatar
My bad, yes, niose filter. As long as you dont have any noise, no problem.
