4 '10's
Old Jul 4, 2002 | 08:46 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
4 '10's
I've this idea. I have 2 10's , 2 250 watt amps and a farad in my car now. I've just come upon 2 more 10's and 2 more 250 watt amps. I've got 2 of them in the classic position in the rear area, same place everyone else does. Question is, would it be possible to mount those 2 additional amps under the rear seats ? Anyone ever tried it ?
Old Jul 4, 2002 | 09:01 PM
mudaholic's Avatar
if they're small, but you have to consider cooling.. they're gonna get pretty hot...
Old Jul 4, 2002 | 09:22 PM
CrazyHawaiian's Avatar
Car: too many ...
You could always mount them on the back part of the fold down rear seats. Others have done this and said they do get a little hot so maybe install some fans back there too? (I used computer case fans once ... newer tech 60mm or 80mm fans for CPU cases flow alot of air).
But honestly I say you re-think the entire setup ... going to 4 10's and 4 amps is getting close to professional grade sounds. You're definately out of the 'common sounds' range. You might want to build an amp rack for all 4 amps with fans and the whole bit. You'll prolly want to upgrade your battery too if you haven't already and definately look into getting a cap. I think it is possible to build a box for the back for 4 10's but they would not all face upwards .. it would take some thought to get correct airspace but I'm sure you could get 4 of them back there. Are they all the same brand subs/amps?
Old Jul 4, 2002 | 10:51 PM
BAK12484's Avatar
good point that he brought up...unless they're the same i'd suggest against it. Mixing different subs together is almost always a bad idea
Old Jul 4, 2002 | 11:04 PM
logikal6785's Avatar
i remember seeing a cap in a post earlier today about stereo but i don't remember exactly what it does - and that is ?
Old Jul 5, 2002 | 01:04 AM
mudaholic's Avatar
a capacitor.. if you have a hundred bucks burning a hole in your pocket with absolutely nothing better to spend it on, you should get one otherwise, invest in something else.. like a better alternator
Old Jul 5, 2002 | 01:12 AM
lol ya i read that a minute before you posted ... it's already on
" THE LIST "
Old Jul 5, 2002 | 11:13 PM
Car: 1987 IROC Z
They are all kenwood subs .. the amps are different, a couple of ghetto amps, ( rockwood and a Legend..? ) the other 2 that are already installed are a kenwood and a Power Accoustics... I believe one is a 1000 watt amp, and the other possibly a 500 ( I didn't buy them, got them with the car) , the other amps are 250's I think.... anyway.. with these specs and 4 kenwood 10's... anyone got any ideas ? Gotta forgive me if some of this info is varying... but what I thought I had is different from what I was just told I had. Im an audiophile of sorts, just not when it comes to car audio....
Old Jul 5, 2002 | 11:19 PM
Car: 1987 IROC Z
Already have the farad, and I have a Interstate Optima Red Top Battery relocated to rear. I'll borrow a digi camera and get some pics of my setup.
Old Jul 6, 2002 | 12:45 AM
Car: too many ...
I dont agree. Every competition level setup runs @ least one cap. Do you honestly think everyone who competes in soundoff comps are idiots?
Old Jul 6, 2002 | 01:46 AM
mudaholic's Avatar
competiton people actually dont have something better to spend the money on what i meant to say, was that for normal listening, you dont need to worry about an exact constant voltage coming into your amp, and furthermore, 99% of the time a capacitor will not alleviate your light-dimming problem... capacitors do have their uses, but most people think that buying one will magically fix all their electrical problems, and it simply wont... for the cost of a capacitor, you could get your alternator rewound to produce more amperage, which will be better for you all over the board, and for most people that is a much better option.. didnt mean to step on anyones toes there, sorry
Old Jul 6, 2002 | 02:00 AM
Car: 1987 IROC Z
Im not really shooting for competition level, personally I prefer crystal clear sound to heart attack bass. Maybe a combination of the 2. Its nice enough with the current setup, just want to see if I can use the others before I sell em. ( assuming I decide to)
