Easy Question
Old Nov 14, 2002 | 09:08 PM
camaro6spd's Avatar
Easy Question
Ok, my friend was talkn to me and said that the amp determins the ohms. Like if you have a 4 ohm sub and hook it up to an amp..say a 2 channel amp and you bridge it you will be running 2 ohms and that can blow up the sub, even if the wattage in within the range of the speaker....is this true. I always thought that the speaker and how you wired it up(such as in series and parrallel) determined what ohm load you where pulling...??? I have an infinity reference 12" sub 300 RMS 4 ohm can i get the Alpine MRD-M300 amp, here are the specs....will i be getting 300 RMS?
And is it all right to run the sub bridged so i get that 300 rms?
150 watts RMS x 1 at 4 ohms
300 watts RMS x 1 at 2 ohms
STAR Topology for cleaner sound
Bass Engine® features:
Low-pass digital crossover, 30-200 Hz, 24 dB/octave
Variable subsonic filter (15-50 Hz in 5 Hz steps)
Parametric EQ variable from 30-160 Hz
Bass Compensator enhances low-end definition
Top-mounted digital control center with cover
Time correction 0-10 milliseconds in 0.5ms steps
Phase correction 0-180° selectable
Digital readout
Detachable front cover
Blue power LED
Delayed turn-on
Speaker- and preamp-level inputs
Gold-plated terminals
8-5/16"W x 2-11/16"H x 11-½"D (10"D without front cover)
Old Nov 14, 2002 | 09:12 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
ya its all in the speakers and how you wire them.
Brian
Old Nov 14, 2002 | 11:10 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
If its one 4 ohm speaker. And its not Dual Voice coil.
You will get 4 Ohms no matter whut with one Single Voice coil 4 ohm sub.
You will be giving that sub 150rms..
Speakers give the resistance not the amp. The amp isn't the load, the speakers are.
On a side note: Dont listen to ur friend he doesn't know wtf he is talking about.
Old Nov 15, 2002 | 10:07 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
the right answer
Well the right answer is that the speaker will always be the same impedance, ALWAYS. BUT, if you drive it with a bridged amp, the amp will "see" half the resistance at each channel. It works like this, if you take a 4-ohm speaker and drive it with a bridged amp the amp will “see” a 2-ohm load on each channel. Now to complicate things. If you take two 4-ohm subs (or a dual voice coil sub with an impedance of 4-ohms per coil) and run them in parallel the speaker load is 2-ohms. If you drive that with a bridged amp each channel of the amp will “see” half of that, or 1-ohm per channel. In this setup if the amp is only 2-ohm stable you run the risk of killing the amp, NOT the speaker. And THAT’S the answer! Got it? Any questions?
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
