Help Me!!!
Old Dec 7, 2002 | 04:02 PM
f0rmula350's Avatar
Help Me!!!
ok i have an alpine tv headunit and on my way home today, i wanted to watch a video. so when i was doin the sequence with the switches, something blew. now my radio wont work or the motor for the rear hatch.... i checked every fuse and there all fine, i am also switching out the tv for my old headunit. i tried that one and it didnt work. is there a hidden fuse box or something?
Old Dec 7, 2002 | 04:18 PM
f0rmula350's Avatar
nobody knows??
Old Dec 7, 2002 | 04:20 PM
mudaholic's Avatar
check your fusible links?
Old Dec 7, 2002 | 07:29 PM
f0rmula350's Avatar
what the hell is that?
Old Dec 8, 2002 | 04:23 PM
mudaholic's Avatar
basically its just a smaller gauge wire thats intended to melt when too much current goes through.. theres one right by your starter, and i think another one somewhere else.. run some searches on the electronics board and you'll get a plethora of information.
Old Dec 10, 2002 | 01:51 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i'm pretty sure you didn't check the fuses correctly
there is a fuse that makes your hatch, horn, and radio work.
go check if your horn works. if it orks then i'm wrong, but if it doesn't i'm right and you should replace this fuse.
Old Dec 10, 2002 | 04:44 PM
f0rmula350's Avatar
somehow the constant power wire doesnt work. i tapped into another wire from my alarm and got my radio to work. for the rear hatch. a wire came out of a harness. so its all fixed, thanks for the replies.
