do i need DVC (dule voice coil) sub
Old Feb 11, 2003 | 02:32 PM
jawzforlife1's Avatar
do i need DVC (duel voice coil) sub
Well I might be getting REZN8R's stealth fiberglass box, so I need a 10" sub, What is a DVC and do I need one, how much better is it than a single and do they cost alot more. Do I need a differnat amp, I currently have a Rockford 500 watt 4ohm amp.
Any suggestion on a sub (DVC or single) 10" to match my 500 watt amp, for about $100-$200
Old Feb 11, 2003 | 03:05 PM
mudaholic's Avatar
DVC subs arent "better" or anything, they generally cost the same amount. they allow more flexible wiring options. how many ohms is your amp stable down to? if it works at 2 ohms, you can get a SVC 2-ohm sub or a DVC 4-ohm sub in order to maximize power output
Old Feb 11, 2003 | 03:16 PM
I belive my amp can saftley go to 4 ohms, How can I find out for sure, Will it tell me in the instruction booklet that came with it.
I really dont need flexible wiring options, I'm just doing one sub with one amp. So should I just do a SVC then.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
