hooking up tweeters?
Old Mar 14, 2003 | 02:02 PM
CamaroEFI's Avatar
i know this is a dumb question but how do wire up another set of speakers if your head unit only has 4 channels (2 dash and 2 sail panels). i want to install a set of tweeters.
Old Mar 14, 2003 | 02:43 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Most head units are only designed to have a 4 ohm speaker load. So if you were to wire them in parallel with the front speakers, it could burn up your headunit. You could wire them in series, where you take the negative wire from the dash speaker and connect it to the positive wire on the tweeter and then connect the negative tweeter wire to the head unit. But the best way would be to use a seperate amp for either the tweeter and dash speakers.
Why do you want to install the tweeters and where were you going to put them?
Old Mar 14, 2003 | 11:23 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
it also epends on what kind of deck you have. if it is a sony or cheapo, i wouldn't do it. i have a 2 ohm load on my panisonic deck on the front channels because of the tweeters, but i plan on adding anouther set, so that would make 3 sets of speakers on the front channels. my deck can handle 4-8 ohm, so i am going to run one set parrallel to the other, then run last set in series. this will equall out the ohm load to 4, which is what i started with. you could do the same, but since you are running 2 sets, you will need to increase your ohm load, so you dont take a chance of damaging your head unit.
good luck
thanks
anthony
Old Mar 17, 2003 | 09:58 AM
CamaroEFI's Avatar
i have the Panasonic 601u 50Wx4ch. im not sure where i want to put the tweeters but it would be along the dash somewhere. i want to take the 4x6's out and put in some kick panels. i've heard the difference between dash speakers and kick panels and kick panels just sound better.
Old Mar 17, 2003 | 01:03 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Hooking up tweeters is completely safe no matter what head unit or amp you're using.
It's true that hooking a pair of 4 ohm speakers together will result in a 2 ohm load that can cook an amp. But... with tweeters you're looking at high frequencies where your amp makes virtually no power anyway. A 2 ohm load at 3khz and up won't even get noticed by the amp. As long as your tweeters come with a high-pass crossover, just go ahead and parallel them to your other speakers.
Old Mar 17, 2003 | 07:05 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Some of the more expensive tweeters come with a crossover that sends only lows to the mid and highs to the tweeter. That way only 1 speaker would be playing at 1 time. But just splicing in a tweeter like Jim said will work fine too.
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
