Hooking up alarm to "trunk pin"
Old Jul 15, 2003 | 11:45 AM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
I want to wire up my alarm to go off if the hatch opens. I was going to hook it up to the black/orange wire that goes into the light back there, but when I was testing it, I found something curious....
The wire is grounded when the hatch is open, but now while it is closing. The part I find confusing is when the hatch is fully closed, the wire is grounded again. So this would set the alarm off then would it not?
Does anyone know if the is the correct wire to use? If not, which one should I be using? The input for the alarm can be + or -.
Old Jul 15, 2003 | 03:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
the pin should only be grounded when the hatch is open. If it's grounded with the hatch closed, something isn't right. Either the switch is grounding out by touching something it's not supposed to, or you've got some sort of funky wiring issue.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
