Help! Radio stopped working
Old Jul 28, 2003 | 07:15 PM
MikeVinNC's Avatar
I have a Pioneer DEH-46DH in a 90' RS that suddenly stopped working after 4 years. The deck won't power up at all and the fuses (inline and under the dash) are good. I removed the Pioneer deck and connected the factory (non-bose) radio and it won't power up either. Are there any other fuses that I should check? Any suggestions?
Old Jul 29, 2003 | 08:27 PM
slayer6x6's Avatar
Did you see if you were getting volatage to the constant and switch wires?
Old Jul 30, 2003 | 06:07 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Try cutting the current ground wire and run a new one bypassing the harness. Also run a temporary acc wire to the fuse block to test and see if maybe thats not your problem also bypassing the harness.
Old Aug 16, 2003 | 08:25 AM
MikeVinNC's Avatar
I'm getting voltage to the constant and switch wires when I test them on the factory harness and also with the aftermarket wiring harness attached.
I connected the factory stereo after testing the voltages and it actually worked for a few minutes, but the power to it would cut out when I moved it around. I couldn't get the Pioneer to work at all, even though the voltages checked out. I re-connected the factory stero again and couldn't get it to work again regardless of how I adjusted the wires - although the wires still check out for voltage on the constant and switch.
Since there isn't a good way to check the voltages with either radio attached, would it still be worthwhile to try and bypass the ground or acc wires?
Old Aug 16, 2003 | 10:58 AM
Little Red RS's Avatar
well there is the old school method.. hook the radio up directly to the battery and make sure it stay's up.. if that works.. try to bypass the harness's.. when you rehookup the pioneer deck are you putting it back in to the radio spot or letting it hang out?
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
