need help sub/amp choice
Old Oct 21, 2003 | 12:12 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I want to add some subs to my car but i really have no idea where to really start. i was looking at 2 of these subs Audiobahn AWC12T and this amp Audiobahn A8000T. are these good choices cause i really don't want to spend over like say 400-500 for the subs and amp and these come in that braket.
Audiobahn AWC12T:
Optimized for SPL / Sound Quality
EPDM Rubber Surround
Molded, Textured Injected Poly Cone
Flame Design Chrome Stamped Steel Basket
2” 4-Layer ASV Voice Coil
Lug-Lock Terminals
Mounting Depth: 5 1/16”
Hole Cutout: 10 7/8”
Outer Diameter: 12 1/4”
Rec. Sealed Box Dims: 0.75 - 2.00 cu.ft.
Rec. Ported Box Dims: 1.30 - 3.30 cu.ft.
Free Air Usage: not recommended
Sensitivity: 92.9 dB
Frequency Response: 25-800 Hz
Recommended RMS Power: 500W
Peak Power Handling: 1000W
Impedance: dual 4 ohms
Audiobahn A8000T:
400 watts RMS x 1 at 4 ohms 800 watts RMS x 1 at 2 ohms MOSFET power supply requires 4-gauge power and ground leads — wiring and hardware not included with amplifier two 30-amp fuses 50-120 Hz low-pass crossover, 18 dB/octave variable bass boost (0-18 dB at 50 Hz) variable (20-50 Hz) subsonic filter preamp outputs cooling fan cobalt blue illumination speaker- and preamp-level inputs 11-5/16"W x 2-5/8"H x 13-1/4"D 1-year warranty
Old Oct 21, 2003 | 01:18 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I'd go with it.
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
david068513
Sep 18, 2015 10:36 AM
ericjon262
Sep 11, 2015 06:07 PM
