Interferance....help?
Old Nov 18, 2003 | 05:08 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I have alpine type-R 6x9's in the back running to a apine v12 amp....i am not using the speaker leads from the front of the car. .....also i have 2 alpine type S subs running on a rockford 360.2 amp......i can hear a buzzing noise even when the volume on the CD player is on "0" ....i was wondering if the amps could be two close together or if the power wire was interfearing with the fuel pump or what.....any ideas?
P.S....i have one power wire coming from the battery and put into a power splitter to have the two power wires for my amp coming out...if thats any help....
any help would be greatly appreciated
Thanks,
25thredrs
Old Nov 18, 2003 | 10:33 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
Sounds like you have a grounding problem. Re-check your grounds and make sure they are all good. Just one loose wire can make weird things happen.
Old Nov 19, 2003 | 09:02 AM
87 GTA TPI's Avatar
Car: 1987 Pontiac Trans am GTA
Engine: 5.0L
Transmission: Dead 700r4
v
Old Nov 19, 2003 | 12:56 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
The buzzing used to go up and down with the RPM's which led me to beleive that it was something to do with the fuel pump....but i'm going to check all my grounds and make sure that they are good....Thanks for the help..
Thanks,
25thredrs
Old Nov 19, 2003 | 09:11 PM
Faded's Avatar
Car: '91 Firebird
I had this problem, too. When you turn on/off the headlights do the speakers pop? And yes, it was a grounding problem.
Old Nov 19, 2003 | 09:18 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
well not when i turn the headlights off but when i use a lot of power from the battery....heat, wipers, brights, radio...etc.. the humming will get louder...i'm goin to check my grounds tomorrow..hopefully i will fix it....it's not that bad at all...just enough to be annoying...thanks for the help
