here is what i came up with
Old Nov 23, 2003 | 07:35 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
well i think i finally decided on what i will be putting in my Camaro come spring
http://www.ikesound.com/customer_acc.../item_id/64872
the 4x6 plate speakers will be powered by the HU
the 6x9's and the component set will be powered by the 300.4
and the subs will be powered by the 800.2
now there are a few other things that i will need(such as distro block, cap, wiring and the kickpanels) but that is the basic set up.
Old Nov 23, 2003 | 07:38 PM
92MaroRS's Avatar
also if i run that apm in tri-mode what would be the out put then? i want a little more than 38 watts for my 6x9's but the 38 watts will be just right from the component set.
Old Nov 23, 2003 | 07:41 PM
92MaroRS's Avatar
update
looked at the component set and noticed they can take more power so i got a bigger amp
600.4
