got a quick question
Old Dec 8, 2003 | 08:42 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
within the next few days i plan on ordering my subs. they will be dual voice coil and i need to know what ohm to get i need to run `2 so it makes a 2 ohm load to the amp.
TIA
Old Dec 9, 2003 | 10:51 AM
92MaroRS's Avatar
anyone? will dual 4ohm subs do the job?
Old Dec 9, 2003 | 12:53 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
If you are getting 1 sub, the DVC 4 ohm is what you want in order to achieve a two ohm load on the amp.
If you are getting 2 subs the DVC 2ohm is what you want in order to achieve a two ohm load on the amp.
http://www.jlaudio.com/tutorials/wiring/index.html
Old Dec 9, 2003 | 08:44 PM
92MaroRS's Avatar
ok i will be getting 2 subs. and just to make sure i got this straight:
i connect the + on one coil to the - of the other coil.
then i connect the other + with the other - and run that to the amp? i do this for both subs right?
Old Dec 10, 2003 | 12:13 AM
Engine: 5.0L
http://www.sounddomain.com/shop/woof...dvc&x=137&y=13
That sounds right
Old Dec 10, 2003 | 01:04 PM
92MaroRS's Avatar
what color is my int. just so im sure i get the right color of kicks
out of these colors:
blue
gray
beige
black
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
