I think this might be a dumb question
Old Jan 21, 2004 | 09:39 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Here it is.....I have two Infinity perfect 12.1 12's with a watt max of 350 each. If I was to buy a Mono Sub amp and run these suckers in parallel (2 ohm load right??) How high can I go on the wattage???? Do I have to stay at the 350 Watt level for both???
I know this is probably a dumb a$$ question, but I have to know.
Thanks as Always
Old Jan 21, 2004 | 09:59 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You want to match the RMS rating of the subs, or slightly higher. Not the peak power.
Old Jan 21, 2004 | 10:02 PM
RMS rating meaning total of subs or per sub.......Example the below stats are for one:
Key Features:
aluminum cone
high-roll butyl-rubber surround
massive cast-aluminum basket
suitable for free-air use (handles up to 175 watts in free-air applications)
recommended power range 75-350 watts RMS
peak power handling 1,400 watts
frequency response 18-200 Hz
sensitivity 96 dB
top mount depth 6-1/8"
sealed box volume: 1.0 cu. ft.
ported box volume: 1.75 cu. ft.
SO I can only go to 350 Watts correct?????
Thanks bro for the quick reply
Old Jan 22, 2004 | 12:37 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Key Features:
aluminum cone
sensitivity 96 dB
perfects will take 600 watts each in a sealed box...i recommend running a JBL 1200.1 to the pair
Old Jan 22, 2004 | 03:54 PM
AJ_92RS's Avatar
Key Features:
aluminum cone
sensitivity 96 dB
Glad you posted that. I misunderstood your question based on "with a watt max".
An amp that produces 300-350 watts RMS per sub would be fine. Or, as "boy" has suggested, a mono amp of 600-800 watts @ 2 ohms would be fine also.
Old Jan 22, 2004 | 06:38 PM
Thanks Guys....You rock!!! Mono sub amp here I come!!
Later
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
