Dyno-mat.....
Old Aug 21, 2004 | 11:07 PM
Gr89RS's Avatar
Car: '02 Z06
Dyno-mat.....
hey if you surround the speakers completely with dyno-mat or another sound deadening material, will it help make plastic and other peices in the car stop shaking and rattling?????
Old Aug 22, 2004 | 08:04 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I really don't know, but I see a ton of people viewed and didn't say anything so I'll leave something.
It will help with sheet metal flexing, but as for plastic trim shaking I kinda doubt it. You might try looking around http://dynamat.com/ They have installations on about every product on various parts of the car (floor, doors, hood, trunk, carputer, etc) . Maybe you can find something out there.
Old Aug 22, 2004 | 05:58 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the whole point of (overpriced) dynamat and similar materials is to stop stuff from vibrating, which is what causes your rattles. you can also put thin strips of foam between panels to stop them from rubbing against each other or use undercoating in places you cant reach with the sheets.
oh, and skip on the dynamat brand. go to home depot/lowes and pick up peel and seel from the roofing/skylighting sections. its the same product at a tiny fraction of the price.
Old Aug 22, 2004 | 07:58 PM
Rage13's Avatar
Car: 89 Firebird
is there a site that sells that peel and seel stuff? i've not been able to find it any where in my area..
Old Aug 22, 2004 | 08:42 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Me too, all i get is like a shingle on the other side.
Old Aug 23, 2004 | 02:39 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Peel & Seal isn't the same stuff. The difference is that dynamat and the other similar products from other brands are rated for around 250* farenheit. P&S is rated for around 150. A lot of people have had problems with P&S falling off in the heat. This is obviously going to make a serious mess if you do your roof or doors with it, but if you're doing the floor, it's a great way to save some money.
I used it on the outer door skins of my girlfriend's camry, and so far it's been working very well... but we also haven't had any heat this summer.
Overall, I'd say it's great for floors and even vertical applications if it's in a location where separating won't cause big problems. For upside down locations, and hot vertical locations, I'd probably say it's worth getting raped for the expensive stuff.
Old Aug 23, 2004 | 07:06 PM
Engine: 383 SBC
You guys might check out ikesound.com they carry dynamat products: bulk packs of orginal is 95 bucks and xtreme $115 for bulk. Shoot that price to thezeb.com or similair place and have them price match it they should knock a few more bucks off the total.
Old Aug 24, 2004 | 06:47 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i havent had any problems yet with the stuff i put down. i only covered the back half of the car, so i dont have any large vertical areas like the doors. the car has gotten quite hot inside this summer and everything is still staying put. however, i'll deal with the possibility of a mess for a much smaller price.
Old Aug 25, 2004 | 07:42 AM
Engine: 383 SBC
Has anyone seen the deadener off ebay? 100 SQ feet for $120 shipped.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Supposely 70 MILS thick.
Here's another link to same product I believe by a different seller.
Old Aug 28, 2004 | 09:04 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
this is what i got it is suposed to be the best stuff out there and the price is decent for this stuff. i;ll let ya know how it works when i get it.
http://cgi.ebay.com/ws/eBayISAPI.dll...715944905&rd=1
Jeff
Old Aug 29, 2004 | 10:47 PM
irocz eric's Avatar
Car: 86 "Ram Air" IROC
Engine: 305 5.Slow
Jeff
pretty expensive...anxious to know the results though.
Old Aug 30, 2004 | 06:34 AM
9177's Avatar
http://www.edesignaudio.com/edead.htm
Try the v3 it is a liquid that rolls on thin and doesn't stink like asphalt plus it also has rust inhibitors.
Old Sep 1, 2004 | 10:11 PM
JeffW's Avatar
Engine: 305 tpi LB9
installed the brown bread yesterday. easy to work with i wore mechanics gloves and cut it with a utility knife. was easier to cut the foil side and gave a better cut too. stuff had almost no smell sticks well. it seems to quiet the panels of the car good i have the doors left to do once i adjust my windows.
jeff
Old Sep 2, 2004 | 01:01 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Peel 'N Seal is available at most roofing/building material supply stores, every town has them. It takes about 120 sq. ft. to do a t-top car like mine. To help with adhesion use a paint-prep product like Total Prep, it seems to help quite a bit. I live in Florida and did have a piece come off of the firewall ledge this summer. To use it on your doors drill smalll holes every 4-6" across the top of the door edge and use the plastic push-in buttons to secure it.
Old Sep 2, 2004 | 01:03 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
And here is the hatch area...
Old Sep 3, 2004 | 02:50 AM
irocz eric's Avatar
Engine: 305 5.Slow
I should really do this to my car...
Old Sep 7, 2004 | 06:20 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
How is the rattle can sound deadner? Does it work halfway deacent? I am thinking about spraying my floor with it when i change my carpet out. I know dyno mat works but its to expensive for me.
Old Sep 13, 2004 | 09:58 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
One of my buddies had a r1cer civic hatchback that would rattle really bad when he turned his 15" L7 to the max, he went to walmart and bought one of those pads you lay on in the swimming pool (2 inch thick foam) and cut it up in small pieces and put it around his weather stripping and cocked it in. Didn't rattle nearly as bad!
Old Sep 13, 2004 | 11:47 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Yes you should! I just returned from Atlanta and after a 800 mile road trip I must say... WOW! The car is so quiet now it's like a different car! No more road noise, sqeaks, the doors don't rattle, the stereo sounds 50% louder, the interior stays cooler... I cannot believe how much of a difference this stuff made... And I used the Peel 'N Seal, not the Dynamat!!
Old Sep 14, 2004 | 08:53 AM
middlebird's Avatar
Car: 86 Firebird
Engine: Carb'd 305
Well just my .02, I have done the entire passenger side of my car in the peel n seal early this spring. The car is going through a lot of changes and hasn't been driven and sitting in the GA heat all summer long none of it has loosened one bit. I covered all the floors, door panels and the sail panels and what little bit of roof I have.
Definitely cost effective!
