Back 6x9's?
Old Dec 26, 2004 | 05:19 PM
BlackMagic's Avatar
Car: 1986 Firebird
Back 6x9's?
Since the day taht I had bought my car i was under the impression that there were 6x9 in teh back of my car by the passengers. Well it was not until today that i began to explore behind the panels to see the condition of the speakers when i came to find a 4in and another smaller oval speaker. Is this how they came stock or was this a custom crappy installation done on my car by the previous owner!
Old Dec 26, 2004 | 06:05 PM
CaysE's Avatar
That's the stock Bose setup. Do you have speakers in your kickpanels, too?
Old Dec 26, 2004 | 06:55 PM
BlackMagic's Avatar
Car: 1986 Firebird
no i dont have any speakers in my kick panels...i have thought about putting some there but decided against it! I decided to put them in the door instead
Old Dec 27, 2004 | 09:32 AM
CaysE's Avatar
Maybe someone swapped out the kickpanels? I'm almost positive that sail panel setup is from the factory Bose option.
Old Dec 27, 2004 | 05:41 PM
mgomez's Avatar
Car: '88 Trans Am/'96 Trans Am
Engine: L98/LT1
Transmission: 700R-4/T-56
Axle/Gears: 3.42/4.10
On the firebirds the bose system consisted of two 4" subs and two 4x6" speakers in the sail panels. They still used the stock dash 4x6" speakers up front. In camaros, the bose system consisted of a extra set of speakers in special kick panels and a extra set of 4x6" (I think that's the size) in the locking rear hatch cover.
Old Dec 28, 2004 | 02:28 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
why did the camaro get such a better system? (budy of mines Iroc has that bose setup, kicks, sail pannels, hatch area) and it rocks for being a factory setup.
Old Dec 28, 2004 | 08:00 AM
CaysE's Avatar
Thanks for the clarification, mgomez... and welcome to TGO.
Old Dec 28, 2004 | 08:05 AM
mgomez's Avatar
Engine: L98/LT1
Thanks cayse glad to be here. The camaro system wasn't any better than the firebird's, just different. I couldn't tell you why. To me they both sound equally well, except the firebirds had a better head unit. Just opnion
Old Dec 28, 2004 | 11:17 AM
BlackMagic's Avatar
Car: 1986 Firebird
I am not sure if i want to remain with that setup or just replace them with 6x9s. If i did decided to remain with that system i would have to find the speaker plate for the left side, since it was removed before my purchase of the car.
As far as the kickpanels, i do not want to put anything down by my passengers feet. I am nor worried about them being on my side, but its when my brother, Girl Friends, or Moms foot goes through it!
When i do place speakers into the doors, i plan on doing 5" or 6"kenwood speakers and tweeters!
Old Dec 28, 2004 | 02:20 PM
CaysE's Avatar
5 feet?? (hehe... edit your posts, will you??)
I would toss the Bose setup in the sail panels and go with 6" components (or a 6" sub if you can find one).
Old Dec 28, 2004 | 06:57 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
speaker grilles are your best friends BlackMagic
Old Dec 28, 2004 | 08:03 PM
mgomez's Avatar
Engine: L98/LT1
You can keep the setup but replace the speakers with some aftermarket ones. That's what I'm in the middle of doing, but to each his own. I guess it also depends on the style of music you like
Old Dec 28, 2004 | 08:53 PM
BlackMagic's Avatar
Car: 1986 Firebird
I like classic rock when cruising around and racing (EX: I cant drive 55), but when the girlfriend is in the car its rap
Old Dec 28, 2004 | 09:04 PM
mgomez's Avatar
Engine: L98/LT1
Lie to her and tell rap will rattle the car apart I like classic rock, anything from the '80's in particular. I thing that using the BOSE templates and upgrading the actual speakers will give the car a real full sound. Chose the right speakers and it should be smooth sailing from there
Old Dec 28, 2004 | 09:32 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
80's music pwns...... although i find that i listen to diff music depending on whos in the car with me too... i think that my system set up a lil diff would be really ull sounding (ie kickpanels instead of lazy dash mounting)
Old Dec 28, 2004 | 09:54 PM
BlackMagic's Avatar
Car: 1986 Firebird
do you know anywhere that has the BOSE templates, because i am missing the template and speakers on the left side. When i got the car (from an impound lot) there was a ox that filled the whole that was lined in foil. Can you guess how the car got impounded!
Drugrunning...I have found several different items hidden within. Including 2 needels in the door sills
Old Dec 28, 2004 | 09:59 PM
mgomez's Avatar
Engine: L98/LT1
Try www.thirdgenusa.com. He often has those components. Ebay is also a popular source(that's where I got mine). Good luck.
Old Dec 28, 2004 | 11:33 PM
CaysE's Avatar
Make sure you don't have an amp running to those sail speakers. They are meant to power 8ohm speakers, IIRC.
Old Dec 30, 2004 | 10:31 AM
ScrapMaker's Avatar
doesnt the bose system have an external amp, or was it built into the headunit?
Old Jan 2, 2005 | 08:55 PM
mgomez's Avatar
Engine: L98/LT1
There was an external amp it fit in the middle underside of the dash just above and to the right of the head unit
Old Jan 3, 2005 | 09:30 AM
ScrapMaker's Avatar
guess it would be a good time to take that out... because if its meant to run on 10ohm loads or 8 or what not then it won't be sufficient for new speakers.... unless you use the same ohm speakers as the original bose, or if you remove half the number of speakers.... I believe the original ohms were at about 4, right? because each speaker was 8 or so, I bet that amp was a 4-channel, and there were 2 speakers per channel
Old Jan 3, 2005 | 08:45 PM
mgomez's Avatar
Engine: L98/LT1
Bose systems are pretty unique and it isn't normally possible to change out any components unless you replace them with bose stuff. I would completely bypass the entire system if you're going with new speakers. If the amp still works you could sell it. I've seen those things sell for quite a bit on e-bay before. You can then add new amps to your speakers and replace that 15 yr old audio wiring with newer stuff.
Old Jan 4, 2005 | 09:56 AM
ScrapMaker's Avatar
yup that's a really good idea, you might even be able to sell the old bose for enough money to buy a brand new 5/6 channel amp! (wishful thinking)
What I've always wondered, is the bose PLACEMENT any good? The 6inch woofers in the hatch area, the kicks, dash and side 4x6, and 6's? or does some of that sound start to mix and sound bad??
I know that with the original bose system, and a few other cars I've been in... they specifially block certain sounds... for example in my friends '00 camaro, with the crummy monsoon system, the middle speakers, that are right next the the rear passengers, are almost inaudible, they play only medium to deep bass... and the speakers in the hatch area play louder vocals and such... they clearly have done some work somewhere to even out the sound... if you were to just replace all the speakers with new(say 3-way coaxials) you might all-the-sudden have strange highs and mids coming from spots there were never intended...
eh, I really don't know, but I have always like the idea of having more speakers.
Old Jan 4, 2005 | 05:25 PM
mgomez's Avatar
Engine: L98/LT1
Bose is pretty well known for "lifelike" sound reproduction. There systems are always high quality, but I really think they are geared more toward people who like classical music. The way the market their products, the way they explain their products, and the placement/size of their speakers seem to lean toward that. I mean, c'mon 4" subwoofers??????
Old Jan 5, 2005 | 09:48 AM
ScrapMaker's Avatar
hrm does the bose system have the 4" subs in the sails, or just the ones in the hatch area? I think there are two systems I am mixing up... the TA system and the premium bose system...
Old Jan 5, 2005 | 05:51 PM
mgomez's Avatar
Engine: L98/LT1
The firebirds have 4" subs in the sail panels along w/4x6's. The camaros have 6x9 in the sail panels and 4" subs on the security hatch cover in the back
Old Jan 6, 2005 | 09:44 AM
ScrapMaker's Avatar
are these one-way 6x9's in the sails? Because that seems like it would work better than the firebird setup
plus the subs are in the rear so the bass will be deeper
Old Jan 9, 2005 | 07:17 PM
mgomez's Avatar
Engine: L98/LT1
Yes the stock 6x9 will be one way for a stock system. I believe the bose stock system would be too. Keep in mind, the people at bose were masters at creating air channels and ports called acoustic channels to make their speakers sound better. I've personally never heard a intact bose system in these cars operate, so I can only speculate.
Old Jan 10, 2005 | 05:46 PM
ScrapMaker's Avatar
The best stock radio I've ever heard is the monsoon in the camaros...
Old Jan 10, 2005 | 11:17 PM
mgomez's Avatar
Engine: L98/LT1
I've heard that they had alot of problems with the monsoon systems. Stock systems keep getting better, in the 70's and 80's they were kind of bad.
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
