No Lights
Old Apr 5, 2005 | 12:04 AM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
No Lights
If I haden't seen this I would call my interior and tail lights went out after I instaled my cd player....no big deal.....check fuse.....blown....replace....blows....hummmmm....head home and pull cd player.....check wires for original sterio lights.....crimped and tapped up good........find one that isn't....tape it up reinstall cd player and fuse.....turn lights on the f'ing thing blows.......put jumper wire in place of fuse pull cd player......turn lights on good.....plug in cd player all is good........now the twist......plug in ant. and my lights dim jumper wire gets hot.......unplug ant. new fuse all is good.....glad I have an azz load of cd's......no ant.= no reception.......what went wrong????.......
Old Apr 5, 2005 | 07:24 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Check your ground. You should be grounding to a black wire in the harness, not the brown wire. The brown wire in the harness measures as a ground, but when you turn your lights on, there's 12 volts present. I made the same mistake when I did my first install way back, and blew a couple fuses and a half dozen headlight relays before I figured it out. I never had antenna problems though.
Old Apr 5, 2005 | 10:27 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
What Jim85iroc said, use the ground in the harness. The dark brown wire will have current when the lights are on. I did the same thing with my first GTA. Went through a hand full of fuses myself.
Old Apr 6, 2005 | 07:30 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
Thanks guys.....I'm 100% sure that is what I did.....the p.o. had a crimp conection on that wire with one end open......it looked black tested as a ground.......I know what to look out for next time......thanks,Mike
Old Apr 9, 2005 | 03:09 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
any luck?
Old Apr 9, 2005 | 08:27 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
yep........i cut the brown wire away from my ground and spliced my ground into another ground for the interior lights and everything is working perfect now.....I think the reson the ant. was causing all the problems is because it grounded the radio when it was pluged in causing the power from the brown wire to flow in via the ground wire for the cd player.......thanks once again for your help guys.Mike
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
