Prep for adding peal & seal
Old Apr 19, 2005 | 10:13 AM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
What kind of prep work should I do before I use peal and seal on the floorboards. I am worried about rusting under the tar. I guess sanding, priming, and then rustoleum coating would be the best method, right? After that, use a heat gun and a roller, right?
I don't want to spring for dynamat, so peal & seal it is. I will let the car air out prior to driving it.
Jay
Old Apr 19, 2005 | 11:50 AM
9177's Avatar
Make sure you have a clean rust free surface and I would put a few coats of primer on anything that needs repainted. You could also look at some latex based deadeners like the V3
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Dragonsys
Sep 25, 2015 03:51 PM
