Quick question..
Old Jun 6, 2005 | 06:46 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Quick question..
Can a set of two 4 ohm, dual voice coil subwoofers be installed to achieve a 2 ohm load?
I know a set of two 2 ohm dual voice coil subwoofers can be hooked up to acheive a 2 ohm load, but I'm not sure about the dual 4 ohm subs.
Old Jun 6, 2005 | 07:30 AM
defpony's Avatar
Car: 85 iroc z28
u can achieve a 2ohm load with one dual 4ohm sub.
so if u had two subs and two amps, each amp would receive a 2ohm load.
But if you're trying to wire them to one amp then i dont believe you will be able to get a 2ohm load.
I cud be wrong, but i think thats the case.
Old Jun 6, 2005 | 11:43 AM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Re: Quick question..
No. U could do 1ohm or 4ohm... there's other ohm loads u could make too, but none that would work well in the car audio world.
There used to be a coupling device made by Stinger that could present the amp w/ a constant ohm load so u could hook up whatever speakers u wanted, but it was basically a way for competitors to get more power out of their amps w/o moving up to the next power class. Even if it was still available, it'd probably be cheaper to buy new subs that are a better match for the amp.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
