Dynamat questions?
Old Aug 8, 2005 | 10:02 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Dynamat questions?
My friends camaro needs dynamat bad, everything rattles and sound like crap. Is there any alternative rather then using dynamat? The stuff is so expensive and looking for a cheaper idea. I heard ice and water barrier works the same? Thanks guys
Old Aug 9, 2005 | 06:32 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
take a trip to lowes and look for PEEL N SEEL. Its used for roofs or something but Ive heard it works really well.
Old Aug 9, 2005 | 04:09 PM
Kandied91z's Avatar
try tracking down the rattles. when i added the necessary support like sub frame connectors and replaced some of the worn out bushings. things that are common with the car rattling the car was fine with carpet in. the dynomat made a huge difference over road/engine noise and help with rattles with the stereo up though. all the way up with the doors open or closed the car doesn't rattle one bit, even the license plate. i used extreme on everything though.
Old Aug 10, 2005 | 09:56 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I just turn up my stereo and listen for the plastic pieces rattling on the inside... then I stuff a paper towel behind it... problem solved..
although my hatch motor assembly is vibrating a lot, even when driving... as well as the metal locking rods in the doors.... gotta add some extra support/padding in those areas...
Old Aug 21, 2005 | 10:00 AM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
I did this on my fourth gen in the back area haven't gotten up to the front yet. Not as heavy as dynomat. The sound deadeng is fairly good, it wasn't done for insulating purposes it's a heavy dense foam with a sticky back and it's approcimately $11.00 a roll at Lowe's. It took a lot of the road noise and rattles out of the back end of the car, and the resonance that you get with aftermarket exhaust is alot quieter also.
http://mikemercury.home.att.net/sound.htm
Old Aug 23, 2005 | 04:27 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
that is a great article. for a corvette, but whatever. i think i might do that before winter comes.
Old Aug 23, 2005 | 09:30 AM
ScrapMaker's Avatar
man I love the floor on that corvette... COMPLETELY FLAT! wow...
ours is a pain in the ***...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
