Whats going on?
Old Oct 13, 2005 | 02:10 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Whats going on?
Anyone have an idea why when I get on the brake pedal my rear speakers cut out and the headunit dims for a quick flash. Do I have some bad grounds? It doesnt cut out at any other times, not when you turn the headlights on, nothing. Just the brakes.
Old Oct 13, 2005 | 02:34 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
It does sound like a power problem (bad ground/voltage drain). The first thing I would do would be run a new ground wire for the head to a piece of metal (ie the firewall, etc). If you're feeling adventurous since you're already back there, you can also run a new 12v line straight from the battery. Those two things will probably take care of your problem.
