82 original radio
Old Oct 19, 2005 | 07:19 AM
Magnus2's Avatar
Car: 1971 Z28, 1972 RS, 1982 Z28E
Engine: 71=355 72=350 82=LG4 305
Transmission: 71=TH350 72=M21 82=TH200
Axle/Gears: 71&72=10 bolt 3:73 82=10 bolt 3:23
82 original radio
Hi, how did the original radio looked like in a 82 Z28.
Is it the same as in a 86 Camaro or when was it changed?
Magnus
Old Oct 19, 2005 | 08:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It depends on what radio you got. If you got the digital AM/FM radio, or the AM/FM cassette, then it should be the same as the 86 model. However, the standard AM radio was only available through 1985. There was also a premium model available with a 5 band equalizer. I don't know what the first year of availability was for that model (I believe it was 1986), but I'm fairly sure it wasn't available in 82.
You may want to ask this question on the History board if you don't get enough feedback here.
Old Oct 20, 2005 | 07:39 AM
Magnus2's Avatar
Was it the AM/FM radio that was in most cars or just the AM?
Thanks for the help
Magnus
Old Oct 20, 2005 | 08:59 AM
Jim85IROC's Avatar
I believe that the overwhelming majority had the AM/FM or the AM/FM/Cassette. Very few had the misfortune of coming with the AM **** radio like mine did.
Old Oct 20, 2005 | 09:15 AM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
here are a few.
Old Oct 20, 2005 | 09:18 AM
jandl22's Avatar
Engine: 2.5 151 TBI
This is waht I have in my 82
Old Oct 20, 2005 | 09:35 AM
jandl22's Avatar
Engine: 2.5 151 TBI
And here is the AM-FM only
Old Oct 20, 2005 | 09:38 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
My 83 is fitted with its original AM\FM radio supplied when new.
Its not like that one above, its more like the radio casette without the casette !!
Old Oct 20, 2005 | 09:50 AM
Jim85IROC's Avatar
I've never seen that style in a thirdgen. All of the AM-FM thirdgen radios I've seen have been the digital one that looks just like the tape deck.
Old Oct 23, 2005 | 03:13 PM
Magnus2's Avatar
That was interesting pictures, now I know how they look.
I had hoped that there was only one type of radio because it had made my life a lot easier. You see, I don't have the build sheet so I have no clue which one my 82 had from the begining.
Thanks for all the help.
Magnus
Old Oct 24, 2005 | 07:52 AM
Jim85IROC's Avatar
Does your 82 still have the original wiring harness, or at least the original wiring? That will help you figure out at least if it came with the AM radio or if it came with the AM/FM or Cassette radio.
The cars that came with just the AM radio did not have a +12 Volt battery wire... just the switched ignition for power. The cars with the digital AM/FM or AM/FM/Cassette had the standard 21-pin wiring configuration that featured a separate +12 volt battery line.
Old Oct 31, 2005 | 06:14 AM
Magnus2's Avatar
I will check that out, thanks for the tip.
Magnus
Vintageracer
Jan 10, 2020 05:33 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
69 Six Pack
Oct 5, 2015 07:51 PM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
