i just picked up a free 01 Monsoon HU
Old Nov 5, 2005 | 07:56 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
CD player from a 01 Z28 monsoon system.. i have the theft lock code already.. but as far as wiring goes.. are the color's the same for all years?
Old Nov 5, 2005 | 10:51 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
It should be plug and play. But you will have to modify your console for it to fit correctly.
Old Nov 9, 2005 | 02:14 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
do you know where i can get a Male connector with pigtail that plugs INTO the head unit?
Old Nov 9, 2005 | 07:54 AM
f1ls1's Avatar
Engine: LS1/L98
Transmission: A4/A4
Any stereo store should have one.
Old Feb 22, 2006 | 07:41 PM
FormulaDriver89's Avatar
Car: 1989 Formula 350
Engine: L98 TPI 350
Axle/Gears: Factory Locking G80
you dont need one... if your factory wiring is still there then the wiring is just plug and play... assuming your putting it in your 92!? Just a heads up - 89's and up have the same GM 21 Pin Wiring....
Old Feb 22, 2006 | 08:28 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
If you really need one the Metra p/n is 71-1858. Should plug right in though. If it doesn't check the plug in and see if its 3 separate plugs combined to one (white, blue, and black) or just one big one with a spot for a single clip. If it is that one you will need 2 harnesses. 70-1858 and 71-2001 from metra or equivalent.
Old Mar 1, 2006 | 02:09 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
There's nothing special about the monsoon headunit...
it's a standard delco unit with a different plastic faceplate..
monsoon has to do with the speakers and amp...
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
