Fiberglass Sub Box Q
Old Dec 26, 2005 | 10:04 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
hey guys
planning to build a sub box.... going to put it in the rear hatch area well...
i have two 8" Kicker Comp Vr
I am not doing the bottum well.... the last drop where it has two sides for the wheel wells.. im making the bottum of the box level with those wells.
Well i am going tomorrow to put my supports in to the bottum well and prepping my build with cardboard, plastic, and aluminum foil.
my question....
how thick should I go around it? and the lid?
Old Dec 28, 2005 | 07:08 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
alright well
doesn't matter anymore
i just bought off ebay 300 sq. feet of fiberglass matt for 30$ and a gallon of resin for 20$
then prolly another gallon will come from wal mart for 28.99$
so..... just going to put layers on until i run out of something
i'll post pictures if anyone is interested and i can find my digital camera
Old Dec 29, 2005 | 11:02 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Must have missed your original post. Sorry about that.
Thickness is subjective to personal preference, your design, and what subs/power you're going to be using.
The weakest part of a fiberglass box is a long flat wall. These are the most prone to flex. The more curves the better. I plan on building some ribs into by box with either MDF strips or dowels to strengthen the box. The only side I'm going to do is on is the side closest to the hump.
Post pictures!
Old Dec 29, 2005 | 08:40 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
jus bought the gallon of resin and toggle switch today
bid on fiberglass ends 2morro
going to lay down plastic and aluminum foil sunday and take a pic
and on the lid im going to cut a peice of ply wood or mdf... then fiberglass the edges so i get a completely flat surface.....
then make a faceplate out of thin plywood, foam, and vinyl
Old Jan 3, 2006 | 04:13 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
the color makes it look outa place but overall its out of the way and comfortable to grab when im behind the wheel :-)
expecting the fiberglass soon
Old Jan 4, 2006 | 09:09 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
What is the toggle switch for?
Old Jan 4, 2006 | 09:43 PM
Gummie's Avatar
Car: 88 GTA
I've got some progress to report on the events leading up to my box. I've got 3 yards of fleece (way overkill for the top but this way I have extra for future projects) and 120 pounds of assorted mat/cloth. I still need my 5 gallons of uscomposits.com resin, brushes, foil, tape, etc.
Still too cold to really do much so I'm buying random things when I find them at a good price. It probably won't be another two or three months until I start my box
I'm guessing the toggle will be for a neon or something along those lines
Old Jan 4, 2006 | 11:39 PM
Enigma_valar's Avatar
Car: 1991 camaro rs
Engine: v6 3.1
Transmission: auto
question about box . should we use kitty hair to fill in bigger crevices or could we just use more fiberglass mat ? would it make big difference ?
Old Jan 5, 2006 | 08:48 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
uhm
i am not HUGE on fiberglass myself....
i am using just matting myself... i know the kitty hair is ALOT easier to work with...other than that i dont know the pros and cons
oh and by the way
all 30 lbs. of my matting came in!!
so
prepping my hatch this weekend
hopefully next weekend i'll be glassin my *** off
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
