Stop the rattling
Old Dec 31, 2005 | 01:45 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
Stop the rattling
I got a set of pioneer 4x6s up front of my maro and the driver side seems to rattle when i turn on the bass or turn it up. what could be causing this and how do i stop it .
Old Dec 31, 2005 | 04:33 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Check and see if the grill that is over the speaker is actually attached... I dynamatted my whole dash pad to get the rattling to stop up front.
Old Jan 1, 2006 | 12:30 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
it is but it still rattles
Old Jan 1, 2006 | 12:41 PM
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Pull the dashpad out and check to see if there are any loose screws/fasteners or even a loose wire somewhere rattleing on a peice of steel.
Kyle
Old Jan 1, 2006 | 01:48 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If you can't track it down any other way, pull the dash pad and try pressing down on the mounting ears while the rattling occurs to see if you can make it stop. That will at least help ID a way to fix it.
Old Jan 1, 2006 | 04:37 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Put a filter on those 4x6's.
Old Jan 1, 2006 | 06:43 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Indeed! If it's a rattle, then it's just something loose. If it's a buzz, then you NEED to filter the bass out of those speakers.
Old Jan 1, 2006 | 10:10 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
2x
Pull the dash apart (pad off) with the stereo on and touch things with your hand until the rattle stops. Once you've located the rattle then go about fixing it by tightening it down/applying some kind of deadner.
jrdturbo
Mar 31, 2016 02:58 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
