? for the GURUS/BOX SPECS from ALPINE
Old Feb 26, 2006 | 12:36 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I just bought an ALPINE SWR-1242D (12" dual 4 ohm VC's) the "optimum vented box" specs are confusing me. Here are the specs:
External box dementions - 18"x13.5"x16.5"
Vent area - 15"sq(12"x1.25")
VENT LENGTH - 22.75"????????
How can the vent length be 22.75" and the largest side of the box be only 18"?
Kind of confusing to me anyway.
Help
Old Feb 27, 2006 | 12:07 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Try as I might I can't find specs for that sub online to check what you posted. I would look again. That box sounds too small to be ported anyway at 2.3 cubes not including the port, sub displacement, and assuming 0 wall thickness which isn't possible.
Old Feb 27, 2006 | 12:58 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The dimensions are for a slot ported box. The port will have to be L-shaped.
The recommended box does not sound too small.
Gummie, you need to try harder. The manual can be dowloaded here.
The recommended box size range is 1.25 to 2.0 cubic feet.
Old Feb 27, 2006 | 12:01 PM
Gummie's Avatar
Car: 88 GTA
Figures. Alpine's most recent manual on their site is from 04
Old Feb 27, 2006 | 03:29 PM
WillSpeedy's Avatar
AHHH An L shaped port I never thought of that. Thanks guys I knew someone would know.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
