Sub Help!
Old Aug 22, 2006 | 11:08 PM
bizmark13's Avatar
Sub Help!
I have 2 12" subs im trying to wire. only prob is on each sub there are 2 +/- connections on opposing sides. How do i wire these?
Old Aug 22, 2006 | 11:44 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
It depends on how much power your amp puts out and what ohms you want to run. Try this first. take the + terminal on one side of the sub, and run it to the - side. Then use the remaining terminals, and run them to the amp. Do this for both subs.
Old Aug 23, 2006 | 12:50 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Yea, for good help you'll have to tell us the model or specs of the subs and amp. If your amp is suited, you could wire your subs to get maximum power, otherwise, you'll need to wire your subs so you don't fry your amp (like me did ).
