1 sub box to cover only pass. side....
Old Jan 2, 2007 | 08:03 PM
newRSdriver's Avatar
Car: 90 RS
Engine: 305 TBI
Transmission: 5-speed
I just bought a new sub and amp and I need to built a box for it. But i can only put the box on the passengers side becuase i need trunk space for sandbags and baseball gear. Does anyone have pictures or dimensions of a box like this?
Thanks Andrew
Old Jan 2, 2007 | 11:41 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
You can build a box to fit anywhere you want it, what size sub, and what kind of box? ported or sealed, and how much space do you need? box volume.
Old Jan 3, 2007 | 04:45 PM
Car: 90 RS
Engine: 305 TBI
it is a single ten inch MTX. I believe it needs .75 cubic ft, sealed box. I am not sure what you mean by how much space I need....if you mean trunk space? then no more than half the well. i need the other half for baseball gear and sandbags. gets pretty icy in jersey.
Old Jan 3, 2007 | 06:12 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i plan on doing this right here
https://www.thirdgen.org/forums/car-...h-gen-sub.html
amp over in the other side wrere spare tire is with wires running under the fkoor and back seats casue i only run 1 sub as well on a 4 channel amp with a rockford frosgates stage 1 punch
Old Jan 3, 2007 | 11:59 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I meant the sealed volume. The .75, that is about what my sub needed, I made a plate to go all the was across and bout half way up the well for looks, but you could Easley make it only half the well. Some of the subs these guys are running need crazy volume, and big *** boxes, so those would be a problem.
HP52TA
Feb 3, 2018 10:51 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Amillionoh7
Sep 5, 2015 11:44 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
