lost about delco
Old Jan 25, 2007 | 01:18 AM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
lost about delco
I have some questions and some things i need clearing up about swaping an delco cd player in to my 87 t/a with the tape deck
1st is it a plug in play kind of thing or do i have to modify the factory harness to accept the newer delco unit
2nd what is the best year range to find one out of if there is any diffrence
Thanks for any help this is my first venture into the stero world never bothered before that it didnt work
Old Jan 25, 2007 | 01:44 PM
ErickL86TA's Avatar
You can buy an adapter that plugs in to your factory wiring. I just installed a factory cd player (from an 1992 T/A) in my 86 T/A. It was a piece of cake.
I have one out of an 1996 Pontiac transport that would be perfect for a swap....its a hard to find unit I picked off of ebay, that I may not use.
Erick
Old Jan 26, 2007 | 12:23 AM
Car: 87 T/A
where do you get the adapter
Old Jan 26, 2007 | 06:17 AM
ErickL86TA's Avatar
E-bay is were I got mine.
Old Jan 26, 2007 | 08:36 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
If you're getting the CD player from a car yourself just cut the wires and splice into your present wiring. The plugs are different in the new units compared to yours. Later CD players, say 2000 and newer (?) have cooling fans on the back, might cause clearance problems in the rear. I put a 97 CD player in mine and only had to trim the flange off the back of the face plate where it hit the radio. Looks factory when done.
Old Feb 6, 2007 | 11:19 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I installed this Delco CD Player in my 86 Iroc.This unit was pulled from a 1993 Buick Roadmaster Wagon.I used an adaptor that i pulled from a junkyard car and just spliced the ends from the cd radio connector to the adaptor.That way I didnt have to cut the factory wiring that I had spliced back in.The previous owner had butcherd the wires for an aftermarket pos unit.Thank god for junkyards
1992Z28!
Nov 19, 2015 07:33 AM
Reid Fleming
Oct 10, 2015 09:56 PM
3.8TransAM
Sep 27, 2015 08:37 PM
BLK87Z
Sep 18, 2015 11:29 PM
snowflake
Sep 16, 2015 09:24 PM
