Dumb question
Old Mar 3, 2007 | 02:55 PM
rebel1222's Avatar
Car: Looking
Dumb question
After using the search feature I cannot find an answer to this question.
I'm trying to install Sony cd player in my 88 camaro. The factory noe is shorter and the new one will not fit. Is there any remedy for this?
Please help.
Kevin
Old Mar 3, 2007 | 04:23 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
two options... First buy the install kit that bolts to the car and then the HU fits into it. drawback is that the HU will stick out about an inch to 1.5 inches in front.
Second option and the way I did mine... Your HU is hitting the ducting for the center console vents that blow at the front of your seats right under the stereo. I took a drill and drilled the crap outta the ducts inside the console so that I could remove about 2 inches of them and then put a layer of FG over the openings so air wouldn't blow into the back of my HU. that gave me enough room for my HU to slide all the way in like it should and sit flush with the console..
Old Mar 3, 2007 | 05:12 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
theres also http://maptechenterprises.netfirms.c...9e75496cd85fa9
bit i think it still sits outs far
Old Mar 3, 2007 | 05:30 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
^^^^^ damn too bad they dont have those for 3rd gens :[ those would be nice.. ive always liked how the trans am and camaro ss filler plates looked.. damn sexy
Old Mar 3, 2007 | 05:36 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
i put one with the install kit in ine and even though it sticks out a little it looks just fine
Old Mar 4, 2007 | 12:20 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
Like a few have mentioned, to get the deck to sit nice and flush, you will have to trim the vents a bit in the back. However, it will look much better than the standard install kit.
Another bonus (which saved my stuff a couple times) was that when you use the flush mount kit, you can lay a dummy face over it to look like a stock radio when the face is removed.
Old Mar 4, 2007 | 01:58 PM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
in mine there was a metal bracket behind, i just muscled it back as far as i could and it sits pretty nice in there
and they do make those lit ones for third gens but i could think of a lot more things to spend $72 on
Old Mar 4, 2007 | 07:42 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
I almost completely forgot about that bracket. I ended up pulling mine out. the console was no less rigid without it.
oh, and found some pics of the setup with the flush mount install kit
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
