sub & amp mounting questions
Subscribe
Mar 23, 2007 | 11:48 PM
can i put a 10' sub where the rear storage box used to be? & can i mount the amp on the passenger side rear fender inside the car?
Reply 0
Mar 24, 2007 | 07:10 AM
Re: sub & amp mounting questions
you can but you need to make your own box and it wont be luad as a single 10 in a well box casue of less air space
Reply 0
Mar 24, 2007 | 09:11 AM
you would also have to make a rack for that amp to mount to.. i hope you wouldnt be mounting it straight onto the fender :P.. but an amp in there may overheat or have a hard time cooling
Reply 0
Mar 24, 2007 | 02:26 PM
what about under the passenger seat?
Reply 0
Mar 24, 2007 | 04:45 PM
I know a few people who have mounted them under the PS seat, it will work if the amp fits under the seat. It may get hot but shouldnt overheat.
Reply 0
Mar 24, 2007 | 10:56 PM
^^^ yup.. it may get hot but under the seat is always covered so no sun is on it or anything.. the side of the car on the fender would be like an oven.. well at least in my dark blue t/a
Reply 0
Mar 25, 2007 | 12:32 AM
it's a pretty small amp so it should fit under the seat, my car has t-tops, a rear cargo shade & is my daily driver in the summer, so i have to mount everything out of the way,& route the wireing the same way, my nephew says the 10's are pretty loud, even without an amp, once i get to the point where i can start putting the car back together (i'm doing an interior swap, replaceing the hood & fenders & painting the car) he's going to help me wire everything up.
Reply 0
Mar 25, 2007 | 12:23 PM
how are you running woofers without an amp?
Reply 0
Mar 25, 2007 | 01:17 PM
Subs should be ran with an amp, put a crossover on it and run low pass only. It will sound much better. Also, when you run the wires, run the power wires away from the speaker wires to avoid noise from the power side. Just some suggestions. Im no expert, but I've learned a few things as many times as I've done these
Reply 0
Mar 25, 2007 | 06:13 PM
he has the subs & the amp, originally i had a 12' sony Xplod that he said he was going to buy off me wich he never did, then i found out a couple days ago he traded it for 2 10's, i had an idea how to run the wires seperate when i was going to put the amp in the trunk but now i have to figure something else out,, i wonder if i can put the amp inder the drivers side rear seat? probably not...
if i could get one of those custom made sub boxes for Camaros/Firebirds for cheap i would do that & put the amp in the storage box, maybe i'll find one at the car show i'm going to next month.
Reply 0
Subscribe
