subs cutting out?
Old Apr 25, 2007 | 10:20 PM
87_firebird's Avatar
Car: rebuilding a 1987 Firebird
Engine: 350 nuttin to special
Transmission: looking for a 6 speed
subs cutting out?
Ok here is what i have Pioneer head unit 40x4 watts, 2 6x9 pioneer speakers both 240 watts, 2 12in pioneer subs both 800 watts, 2 pioneeer amps 760 watts a piece and they are running off a second battary and each have a capacitor. the only way i can half *** turn it up is if i turn the bass boost down and the bass all the way down on my stereo. then when i turn it up to a certain level the subs just quit. Do i have to much watts running through it? or is it sumthing else?
Old Apr 26, 2007 | 12:28 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: subs cutting out?
Are the amps - one amp per sub? How are they wired, what is the impedence of the subs and are they dual or single voice coil?
Old Apr 26, 2007 | 11:25 AM
1 sub per amp, wiring: wired the speacker wires, audio wires, and system control wires from the stereo to the amps then wired the amp to the subs and the power wires for the amps are ran through the 2 capacitor then to the battary.
Old Apr 27, 2007 | 10:33 PM
o and 4 ohms / 4 layer, long voice coil design: high power abd long excurrsion capability for deeper louder more inpactful bass( that what the manu says)
Old Apr 28, 2007 | 08:59 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
the subs are 4ohms? or you wired it at 4ohms?.. a 4ohm cant be wired to 4ohm,unless it has a single 4ohm vc..dvc4ohm can only be wired to 2 or 8 depending on the wiring
Old Apr 28, 2007 | 12:57 PM
subs are 4 ohms
Old Apr 28, 2007 | 11:37 PM
stew_pidaso59's Avatar
put a good cap on it
Old Apr 29, 2007 | 08:56 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
haha! his system dont need a cap at all , but i can also not tell you why there cutting out , i can tell you , you dont need a cap , if your going to install a cap do a bigger battery and alt first a caps a waste of money
Old Apr 29, 2007 | 11:12 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
1. Both amps cut out at the same time?
2. How are things grounded?
3. Have you taken a DMM out and mesued the resistance of the subs?
4. What modle amp and is the power light going out, or dimming with the bass?
Old Apr 29, 2007 | 09:46 PM
the amps are fine the subs just stop at a certain sound level
Old Apr 29, 2007 | 10:37 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Have you tried the grounds yet.
Old Apr 30, 2007 | 12:05 AM
the amps ground wires are ran to the battary
Old May 3, 2007 | 09:55 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
So how are the sub hooked up? Two subs, are they run in parallel off one amp bridged? Or one amp, one sub to a channel?
And the power light on the amp stays on? Depending on the model that may not mean much, some of them the light just stay on when the amp goes into protect.
Can you measure the resistance of the subs?
Old May 3, 2007 | 03:06 PM
TheBandit's Avatar
Engine: Poncho 350
dont put a cap on it -_-
Old May 3, 2007 | 04:25 PM
ok unhooked everything and rewired it it works fine now dont know what i had wrong thanks for all the help.
Old May 3, 2007 | 08:59 PM
TheBandit's Avatar
Engine: Poncho 350
maybe just a weak ground connection.. but glad to hear its working alright now
Old May 4, 2007 | 07:39 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
pioneer subs have a saftery cutoff @ a certain power limit . thats the bad thing about them, unless u have the premier sub which holds the record!, they dont! try some other subs if it consists ok! if u need anything just holla, and he is right 4ohm dvcs can only run 2 or 8 ohms! 2ohm dvc and 8 ohm dvc can run @ 4ohms!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
