Multiple Subs in 1 ported enclosure ?
Old May 10, 2007 | 06:06 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
So if 1 ported sub uses 1.0 cf air space & a 2" x 6" port, can I build a 2.0 cf box with 2 2"x6" ports and use 2 subs?
If not, how do I figure this out??
Raf
Old May 10, 2007 | 08:03 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: Multiple Subs in 1 ported enclosure ?
why not just do what your doing and make seperate chambers?
Old May 10, 2007 | 08:26 PM
luvofjah's Avatar
I'm trying to build a ported enclosure for 4 8" subs.
Have you seen the shape of a 3rd gen trunk? the bottom well is off to one side, using an angle and going forward I can probably get enough air space (.7 each sub) and the ports, but making 4 equal cf chambers... would be rather difficult...
I can still brace the box inside....
Raf
Old May 11, 2007 | 02:35 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I have seen a guy with two 8" subs with 1.25 cf ported hit 138.00 db thats really good for two small speakers,i have two 12''s and i was thinking of doing two 8'' subs in a isobaric bandpass in my gta
Old May 11, 2007 | 02:41 AM
luvofjah's Avatar
The only things I've seen concerning sharing air space are the rigidity of the box (which can be braced) & the other is "what if 1 woofer fails, the other('s) will soon fail too...."
Any other concerns?
Raf
Old May 11, 2007 | 04:05 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Download Win ISD and it will work it out for you. The calculations aren't really that simple when you put 2 subs in 1 space. I've made several boxes like this using win ISD and have never been dissapointed.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Dragonsys
Sep 25, 2015 03:51 PM
