Kicker kx1200.1 for 2 CVR12's
Subscribe
Jun 9, 2007 | 12:57 PM
I curently have 2 kicker cvr12's running off of a 600w 4 channel sony amp with my 6x9s on the same amp, well yesterday I found a brand new kicker kx1200.1 monoblock on ebay for $300 shipped so I picked it up. I plan on leaving the sony for my 6x9s and putting the kicker on my subs. I was wondering if my battery will survive? and if the amp will be too big for the subs?
Thanks for the help guys
Reply 0
Jun 9, 2007 | 03:23 PM
Re: Kicker kx1200.1 for 2 CVR12's
stock charging system i assume? i have a 1000 watts going now but if i crank it everything dims and the voltage goes down way to much.. you might want to do the Big 3 and see what happens. Then if you still have significent voltage drop i suggest you look at HO alts. And whatever you do please dont put a capacitor on it. No matter what anyone tells you please dont put a cap on it.
Reply 0
Jun 9, 2007 | 11:22 PM
Big 3?
Reply 0
Jun 10, 2007 | 11:02 AM
http://www.the12volt.com/installbay/...TID~73496~PN~1
basically its changing the 1)pos. wire from the alt to the pos batt. 2)battery negative to chassis 3)engine ground to chassis... your changing all these wires to a bigger gauge, im not sure what ours is now but you should change it to 0 gauge and that will help a lot
Reply 0
Jun 10, 2007 | 12:39 PM
thanks I will change them when I install the amp!! Im just a little worried about the amp blowing the speakers
Reply 0
Jun 11, 2007 | 01:44 PM
yeah a 1200 will probably put out around 1400.. there underrated.. set the gains low so you dont blow them
Reply 0
Subscribe
