Auxiliary port
Old Jun 12, 2007 | 08:52 PM
Snowblind's Avatar
Car: 1988 t/a gta
Transmission: manual
Auxiliary port
Do they make kits to attach an auxiliary port to a stock head unit? i have a 1988 firebird trans am gta with the steering wheel controls, ac delco head unit. I want it so i can connect my mp3, i hate fm transmitters and my tape deck is busted.
Old Jun 13, 2007 | 12:48 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Auxiliary port
I think you just ruled out your best option.
There is no known kit available. In order to adapt a hardwired modification, as opposed to sending the signal via an FM transmitter, would entail modifying the stock radio's internal circuits pior to it's amplification circuit and it would likely needed to be "switched" to avoid interference with signals coming from the radio circuit or the tape player. And the signal levels would need to be matched closely to avoid overloading the stock radio's preamplification circuit.
Go with the FM transmitter or just swap out the stock unit with an aftermarket headunit. With the wiring and installation kits available today, this can be done and reversed back to original a any time without any damage or problems. Although you will likely lose the steering wheel controls.
Old Jun 23, 2007 | 10:25 PM
Snowblind's Avatar
Car: 1988 t/a gta
Re: Auxiliary port
got this head unit. hooked up a flash drive to the usb and my mp3 to the aux. now i just need to get the steering wheel adapter : )
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
