static when i have my headlights on
Old Nov 12, 2007 | 08:53 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
hi, i have a 1990 camaro rs and i have all new speakers put in my car. i also have a fairlly good cap in my car as well but when im driving down the street and i have on my radio and my headlights i get this weird static like sounds coming out of my speakers. it works fine though with out the static if i dont have my headlights on. almost like im draining too much power from the battery. wuts wrong and how do i fix it? any help greatly appreciated.
Old Nov 12, 2007 | 09:34 PM
cdoyle's Avatar
Re: static when i have my headlights on
Do you have an amp?
Check all your wires, check your ground, try and keep your ground as short as possible.
Just double check everything.
Old Nov 14, 2007 | 11:06 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
this may be a stupid question but are any speaker wires near power wires for the headlights?
Old Nov 14, 2007 | 11:14 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
are the lights dim when they are on? I wonder if there isn't a short in the headlight wiring somewhere
Old Nov 14, 2007 | 07:49 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I get some static on certain, 92-96 FM, radio stations when I turn on my HID headlights, but, if I disconnect the drivers side HID bulb and use a standard headlight, it doesn't have static. So I know it has something to do with the drivers side HID ballast and/or bulb. I even installed a "ground isolator" on the antenna lead near the radio, doesn't help at all.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
